[Osgeo4w-trac] [osgeo4w] #574: gdalbuildvrt fails handling wildcards under Win10 1803
trac_osgeo4w at osgeo.org
Fri Jul 13 05:39:25 PDT 2018
Reporter: Langlaeufer | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: GDAL, |
Comment (by deezx):
I have the same issue with gdalbuildvrt using Win10 (1803)
On my machine building the VRT **fails only for the first file of the
folder in wildcard matching**, other files in same folder are added to the
VRT. So if I have four tiles in a foulder, the first file produces an
error, but the other tree files are added. The first file fails, because
the first filename matching the wildcard is **truncated to a single
char**, e.g. if the file is **folder/abc.tif** the wildcard
**folder/*.tif** produces the following error:
ERROR 4: folder\a: No such file or directory
Warning 1: Can't open folder\a. Skipping it
Issue affects all current Windows versions of QGIS (2.18.21, 3.2.0) using
GDAL 2.2.4 from OSGEO4W build, in Windows 10 (1803), 64bit.
see:
https://github.com/OSGeo/gdal/issues/568
https://issues.qgis.org/issues/19192
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/574#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
