[Osgeo4w-trac] [osgeo4w] #570: pip3
OSGeo4W trac_osgeo4w at osgeo.org
Tue Sep 4 11:54:33 PDT 2018
#570: pip3
Reporter:  rduivenvoorde  |       Owner:  osgeo4w-dev@…
    Type:  defect         |      Status:  new
Priority:  major          |   Component:  Package
 Version:                 |  Resolution:
Keywords:                 |
Comment (by hellik):
 Replying to [comment:8 jef]:
 > Replying to [comment:7 muellea]:
 > > unfortunately the same. Tried py3_env and call py3_env. In both cases
 i can start an interactive python-shell (python3), so environment is set,
 but pip3 refuses to start.
 > Not reproducable here:
 > run o-help for a list of available commands
 > C:\Windows\System32>call py3_env.bat
 > C:\Windows\System32>SET PYTHONPATH=
 > C:\Windows\System32>SET PYTHONHOME=C:\OSGEO4~1\apps\Python36
 > C:\Windows\System32>PATH
 C:\OSGEO4~1\apps\Python36;C:\OSGEO4~1\apps\Python36\Scripts;C:\OSGEO4~1\apps\Python27\Scripts;C:\OSGEO4~1\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\WBem
 > C:\Windows\System32>pip3
 > Usage:
 >   pip3 <command> [options]
 tested here:
 C:\>call py3_env.bat
 C:\>SET PYTHONPATH=
 C:\>SET PYTHONHOME=C:\OSGEO4~1\apps\Python36
 C:\>PATH
 C:\OSGEO4~1\apps\Python36;C:\OSGEO4~1\apps\Python36\Scripts;{app};C:\OSGEO4~1\apps\Python27\Scripts;C:\OSGEO4~1\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\WBem;C:\OSGEO4~1\apps\msys\bin;C:\Program
 Files\R\R-3.4.4\bin\x64
 C:\>pip3
 Fatal error in launcher: Unable to create process using '"'
 C:\>
 ckecked in the OSGeo4W installer wizard, pip3 isn't installed.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/570#comment:13>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
