[Osgeo4w-trac] [osgeo4w] #650: msodbcsql - unknown package
trac_osgeo4w at osgeo.org
Wed Nov 11 17:11:39 PST 2020
Reporter: tobwen | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: minor | Component: Installer
Version: | Resolution:
Keywords: |
Comment (by jonnyforest):
Hi guys,
I had the same problem. I did e fresh install with OSGeo4W64 using UAC and
and the log show:
2020/11/11 09:34:46 running: cmd.exe /c
"C:\OSGeo4W64\\etc\postinstall\msodbcsql.bat"
2020/11/11 09:34:47 abnormal exit: exit code=1603
I had as well the same issue in the commandline of osgeo shell-
I went to the bin folder and did a manual install of msi (right-click open
as administrator) and the problem was solved.
If I try to install using the msiexec method I have the same problem of
tobwen.
I did a quick search about exit code=1603 and can be about permissions or
corrupted .msi
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/650#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
