[Osgeo4w-trac] [osgeo4w] #660: Installation of QGIS-ltr 3.16.4 (32bit) failed
OSGeo4W trac_osgeo4w at osgeo.org
Mon Feb 22 02:22:19 PST 2021
Reporter:  Andreas Müller  |       Owner:  osgeo4w-dev@…
    Type:  defect          |      Status:  new
Priority:  major           |   Component:  Package
 Version:                  |  Resolution:
Keywords:                  |
Comment (by peetwhittaker):
 I also experienced this using the 64-bit OSGeo4W Setup utility (see
 attached for setup log file). During the postinstall script for qgis-ltr-
 common, I got an error message stating that crssync.exe couldn't start
 "because libprotobuf-lite.dll is missing" (see attached image). The
 installer then reported the following info "qgis-ltr-common.bat exit code
 -1073741515".
 Launching QGIS then failed as it "could not load qgis_app.dll" (see
 attached image).
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/660#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
