[Osgeo4w-trac] [osgeo4w] #686: Error installing QGIS 3.16.9 using network installer (was: Error installing QGIS 3.18.9 using network installer)
trac_osgeo4w at osgeo.org
Wed Jul 21 01:24:11 PDT 2021
Reporter: peetwhittaker | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Installer
Version: | Resolution:
Keywords: |
Description changed by jef:
Old description:
> Upgrading from QGIS 3.18.8 to 3.18.9 using the network installer results
> in the following error during the installation procedure:
> {{{crssync.exe The program can't start because icuin56.dll is missing}}}
> This means that the qgis-ltr-common package fails to install correctly
> and QGIS fails to launch, with the following error:
> {{{Error loading QGIS - could not load qgis_app.dll. The specified module
> could not be found.}}}
New description:
Upgrading from QGIS 3.16.8 to 3.16.9 using the network installer results
This means that the qgis-ltr-common package fails to install correctly and
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/686#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
