[Osgeo4w-trac] [osgeo4w] #688: Fiona - DLL load failed while importing ogrext: The specified module could not be found. [AGAIN]
trac_osgeo4w at osgeo.org
Sat Jul 24 12:53:56 PDT 2021
Reporter: ondrejsv | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: major | Component: Package
Version: | Resolution: fixed
Keywords: |
Changes (by jef):
* status: new => closed
* resolution: => fixed
Comment:
Updated to 1.8.20-1.
Replying to [ticket:688 ondrejsv]:
> Note that "workaround" with creating an empty ".lib" directory mentioned
in the #649 does not help. Frankly, if you check the source code file
_loading.py in the fiona, I don't know how it could help.
Because that was a QGIS issue.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/688#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
