[Osgeo4w-trac] [osgeo4w] #682: MSI and EXE installers: different Python locale settings leads to issues with the Python console script editor
    trac_osgeo4w at osgeo.org
    Tue Jun 22 08:58:15 PDT 2021
Reporter:  andreaerdna  |      Owner:  osgeo4w-dev@…
    Type:  defect       |     Status:  new
Priority:  major        |  Component:  Package
 Version:               |   Keywords:
 With the old OSGeo4W repository EXE installer (QGIS 3.18.1):
 import sys
 bool(sys.flags.utf8_mode)
 True
 import locale
 locale.getpreferredencoding(False)
 'UTF-8'
 while with the new OSGeo4W repository MSI installer (QGIS 3.18.1):
 import sys
 False
 import locale
 'cp1252'
 With the new MSI installer, this leads to issues with the Python console
 script editor if the script contains non cp1252 encoded characters, while
 there is no issue with the old EXE installer, as reported on GitHub issue
 tracker https://github.com/qgis/QGIS/issues/43834
 **How to Reproduce**
 Enter
 print('áéŐŰÍ')
 in the Python script editor window and run the script.
 The script will execute without issue using QGIS from the old repository
 EXE installer, while it will generate the following error using QGIS from
 the new repository MSI installer:
   File "F:\QGIS\SOURCE~1\qgis\apps\Python39\lib\code.py", line 90, in
 runcode
     exec(code, self.locals)
   File "<input>", line 1, in <module>
   File "F:\QGIS\SOURCE~1\qgis\apps\Python39\lib\encodings\cp1252.py", line
 23, in decode
     return codecs.charmap_decode(input,self.errors,decoding_table)[0]
 UnicodeDecodeError: 'charmap' codec can't decode byte 0x90 in position 12:
 character maps to <undefined>
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/682>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
