[Osgeo4w-trac] [osgeo4w] #681: no-shortcuts options not working
trac_osgeo4w at osgeo.org
Mon May 17 08:06:02 PDT 2021
Reporter: rhaubourg | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: minor | Component: Package
Version: | Resolution:
Keywords: |
Changes (by jef):
* priority: major => minor
Old description:
> Hi there,
> running
> .\osgeo4w-setup.exe --quiet-mode --root "X:\OSGEO4W_DEPLOY_TEST\INSTALL"
> --local-install --local-package-dir
> "X:\OSGEO4W_DEPLOY_LOCAL\PAQUETS\http%3a%2f%2fwww.norbit.de%2fosgeo4w%2f"
> --autoaccept --no-shortcuts --delete-orphans --upgrade-also -C Libs -C
> Commandline_Utilities -C Desktop
> still creates a menu with the directory name "OSGEO4W_DEPLOY_LOCAL"
> I also tested with --no-starmenu and --no-desktop, but the shortcut
> entries are still created
New description:
Hi there,
running
I also tested with --no-startmenu and --no-desktop, but the shortcut
Comment:
The shortcuts are created by the packages - each package has to respect
the setting of OSGEO4W_DESKTOP_LINKS / OSGEO4W_MENU_LINKS and place the
shortcut into and OSGEO4W_DESKTOP / OSGEO4W_STARTMENU. Which don't? I
suppose GRASS or very old ones. In testing that cruft is probably gone.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/681#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
