[Osgeo4w-trac] [osgeo4w] #700: GRASS not woking with the latest qgis, qgis-ltr, grass, qgis-ltr-grass-plugin, qgis-grass-plugin packages
trac_osgeo4w at osgeo.org
Tue Nov 9 02:30:54 PST 2021
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords:
Updating qgis, qgis-ltr, grass, qgis-ltr-grass-plugin, qgis-grass-plugin
to the latest availabel packages version (with also all the other packages
updated to the latest versions) on Windows 10 64 bit using the OSGeo4W
Network Installer v2:
qgis-ltr 3.16.13-1
qgis-ltr-grass-plugin 3.16.13-1
qgis 3.22.0-4
qgis-grass-plugin 3.22.0-4
grass 7.8.6-6
then the grass algorithms in the QGIS processing toolbox don't work,
showing the following error:
Error executing algorithm
This algorithm cannot be run :-(
The specified GRASS 7 folder "C:\OSGEO4~4\bin\bin" does not contain a
valid set of GRASS 7 modules. Please, go to the Processing settings
dialog, and check that the GRASS 7 folder is correctly configured
Anyway, in the Processing settings dialog there is no longer the
possibility to check and set the GRASS 7 folder configuration.
Moreover, the following warnings are present in the Log Messages panel:
2021-11-09T11:03:29 WARNING Failed to load C:/OSGEO4~4/apps/qgis-
ltr/plugins/grassplugin7.dll (Reason: Cannot load library C:\OSGEO4~4\apps
\qgis-ltr\plugins\grassplugin7.dll: Impossibile trovare il modulo
specificato.)
ltr/plugins/grassprovider7.dll (Reason: Cannot load library
C:\OSGEO4~4\apps\qgis-ltr\plugins\grassprovider7.dll: Impossibile trovare
il modulo specificato.)
ltr/plugins/grassrasterprovider7.dll (Reason: Cannot load library
C:\OSGEO4~4\apps\qgis-ltr\plugins\grassrasterprovider7.dll: Impossibile
trovare il modulo specificato.)
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/700>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
