[Osgeo4w-trac] [osgeo4w] #705: GRASS 7 plugin not working with QGIS 3.22.0 (Module built against version ... but trying to use version ...)
trac_osgeo4w at osgeo.org
Thu Nov 11 03:49:09 PST 2021
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords:
Using QGIS 3.22.0 installed via the OSGeo4W v2 Network Installer (qgis
3.22.0-4) or the Standalone Installer (QGIS-OSGeo4W-3.22.0-3.msi), it is
not possible to use the GRASS7 plugin (qgis-grass-plugin 3.22.0-4, grass
7.8.6-6).
The following error is reported in the Log Messages panel:
2021-11-11T11:36:45 WARNING GRASS init error : Problem in GRASS
initialization, GRASS provider and plugin will not work : Module built
against version 2021-10-11T09:56:15+00:00 but trying to use version
2021-11-01T10:26:16+00:00. You need to rebuild GRASS GIS or untangle
multiple installations.
The issue doesn't occur with QGIS 3.16.13 from OSGeo4W v2 (qgis-ltr
3.16.13-1, qgis-ltr-grass-plugin 3.16.13-1, grass 7.8.6-6) and with QGIS
3.23.0-master (qgis-dev 3.23.0-124-a119884d35-1).
See also https://lists.osgeo.org/pipermail/qgis-
user/2021-November/050159.html
See previous similar issues https://trac.osgeo.org/osgeo4w/ticket/695 and
https://trac.osgeo.org/osgeo4w/ticket/657
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/705>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
