[Osgeo4w-trac] [osgeo4w] #693: Command line install does not create desktop shortcut
trac_osgeo4w at osgeo.org
Sun Oct 3 02:47:31 PDT 2021
Reporter: nicogodet | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Installer
Version: | Keywords:
= Issue =
When running the command
.\osgeo4w-setup.exe --menu-name "QGIS Custom" --root "C:\OSGeo4W"
--advanced --quiet-mode --local-install --local-package-dir
"\\192.168.1.20\PiPartage\DEPLOY\http%%3a%%2f%%2fwww.norbit.de%%2fosgeo4w%%2fv2%%2f"
--autoaccept --delete-orphans --upgrade-also -C Libs -C Desktop -C
Commandline_Utilities
The desktop shortcut is not created.
Line in postinstall script:
if not %OSGEO4W_DESKTOP_LINKS%==0 xxmklink
"%OSGEO4W_DESKTOP%\%APPNAME%.lnk" "%OSGEO4W_ROOT%\bin\qgis-ltr-custom.bat"
"" "%DOCUMENTS%" "" 1 "%OSGEO4W_ROOT%\apps\qgis-ltr\icons\qgis.ico"
Same line in setup.log.full:
C:\OSGeo4W>if not 0 == 0 xxmklink "C:\Users\Nicolas Godet\Desktop/QGIS
ISL\QGIS ISL (LTR).lnk" "C:\\OSGeo4W\bin\qgis-ltr-isl.bat" "" "" "" 1
"C:\\OSGeo4W\apps\qgis-ltr\icons\qgis.ico"
It seems that `OSGEO4W_DESKTOP_LINKS` is always equal to `0` even if
`--no-desktop` option is not specified.
Also noticed that `Create desktop shortcut` checkbox in GUI is disable by
default, could be linked.
= Additional context =
https://github.com/haubourg/custom-osgeo4w-qgis/pull/3
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/693>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
