[Osgeo4w-trac] [osgeo4w] #690: GRASS GIS 8 in OSGeo4W NG
trac_osgeo4w at osgeo.org
Fri Sep 17 04:48:14 PDT 2021
Reporter: sbl | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: grass |
Comment (by sbl):
Thanks for your reply.
For starters I tried (in a Github action), to:
1. Download dependencies from OSGeo4W (so they live in ''/c/OSGeo4W/'',
2. Setting the current working directory to where the ''package.sh'' lives
(''src/grass/osgeo4w'') and run it with ''bash''.
However, although the relative path should be correct, ''build_helpers''
was not found, and after hardcoding the path to ''build_helpers'',
''build_helpers'' was sourced, but then ''genini'' fails:
/d/a/OSGeo4W/OSGeo4W/scripts/genini: can't open x86_64/setup.ini.tmp - No
such file or directory
mv: cannot stat 'x86_64/setup.ini.tmp': No such file or directory
/d/a/OSGeo4W/OSGeo4W/scripts/build-helpers: line 206:
x86_64/setup.ini.bz2: No such file or directory
The attempt to setup the GH action is here:
https://github.com/ninsbl/OSGeo4W/tree/grass_dev_workflows
and the results (error messages) here:
https://github.com/ninsbl/OSGeo4W/runs/3620990391?check_suite_focus=true
My feeling is that something needs to be run before ''package.sh'' (maybe
some environment variables need to be set) or that the script needs to be
called from a different place than where it lives. But I have no idea
where I could find information on that.
If I could get that to work, I could contribute recipies for GRASS
packages (PRs that are tested on GH), and probably even more important
with regards to OSGeo4W integration, I could try to integrate the OSGeo4W
build procedure as the basis for the CI / unittests for GRASS GIS, so new
commits are tested with regards to effects on OSGeo4W builds...
So, e.g. any hint on how to call ''package.sh'' and pre-requisits to do so
successfully, would be a great help and very much appreciated. Thanks.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/690#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
