[Osgeo4w-trac] [osgeo4w] #737: Patch needed for GDAL 3.4.2
    trac_osgeo4w at osgeo.org
    Sun Apr 10 10:18:06 PDT 2022
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Description changed by andreaerdna:
Old description:
> After the update of the {{{gdal}}} package in OSGeo4W to version 3.4.2 in
> order to enable the fix provided by PR
> [https://github.com/qgis/QGIS/pull/47098 QGIS/qgis#47098] for the issue
> [https://github.com/qgis/QGIS/issues/23991 QGIS/qgis#23991], some
> issues caused by the same PR [https://github.com/qgis/QGIS/pull/47098
> QGIS/qgis#47098] have been discovered:
> 1) [https://github.com/qgis/QGIS/issues/48003 QGIS/qgis#48003]
> "Geopackage from network location is not a valid or recognized data
> source"
> 2) [https://github.com/qgis/QGIS/issues/48154 QGIS/qgis#48154] "Adding
> additional layers to GPKG does not load them correctly"
> 3) [https://github.com/qgis/QGIS/issues/48024 QGIS/qgis#48024] "Cannot
> add GeoPackage layer with hash symbol # in file path"
> These issues affects current QGIS 3.25.0-Master and QGIS 3.24.1 when
> built against GDAL 3.4.2. They doesn't affect QGIS LTR 3.22.5, but they
> will affect QGIS LTR 3.22.6.
> While the issues 1) and 2) have been fixed (the first one with
> [https://github.com/qgis/QGIS/pull/48059 qgis#48059] and
> [https://github.com/qgis/QGIS/pull/48119 QGIS/qgis#48119] and the second
> one with [https://github.com/qgis/QGIS/pull/48157 QGIS/qgis#48157]) with
> patches in QGIS (backports for 3.22 and 3.24 branches are awaiting
> merging, which will hopefully happen before the release of the
> forthcoming QGIS versions), the issue 3) has been fixed with a patch in
> GDAL (both in master [https://github.com/OSGeo/gdal/pull/5554
> OSGeo/gdal#5554] and 3.4 [https://github.com/OSGeo/gdal/pull/5571
> OSGeo/gdal#5571] branches).
> So, since a GDAL 3.4.3 release that contains the patch for the issue 3)
> is not yet available, I propose to temporary apply the GDAL patch
> [https://github.com/OSGeo/gdal/pull/5571 OSGeo/gdal#5571] in the OSGeo4W
> {{{gdal}}} package to prevent that the issue 3) will affect the
> forthcoming QGIS 3.24.2 and QGIS LTR 3.22.6.
New description:
 [https://github.com/qgis/QGIS/issues/23991 QGIS/qgis#23991], some issues
 1) [https://github.com/qgis/QGIS/issues/48003 QGIS/qgis#48003] "Geopackage
 from network location is not a valid or recognized data source"
 3) [https://github.com/qgis/QGIS/issues/48024 QGIS/qgis#48024] "Cannot add
 These issues affects current QGIS 3.25.0-Master and QGIS 3.24.1 (qgis
 3.24.1-2) when built against GDAL 3.4.2 (qgis 3.24.1-1 is not affected).
 They doesn't affect QGIS LTR 3.22.5, since the offending PR
 [https://github.com/qgis/QGIS/pull/47098 QGIS/qgis#47098] has been
 backported to 3.22.6.
 merging, which will hopefully happen before the release of the forthcoming
 QGIS versions), the issue 3) has been fixed with a patch in GDAL (both in
 master [https://github.com/OSGeo/gdal/pull/5554 OSGeo/gdal#5554] and 3.4
 [https://github.com/OSGeo/gdal/pull/5571 OSGeo/gdal#5571] branches).
 So, since a GDAL 3.4.3 release that contains the patch for the issue 3) is
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/737#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
