[Osgeo4w-trac] [osgeo4w] #734: GISBASE Environment not set
trac_osgeo4w at osgeo.org
Wed Mar 9 03:37:31 PST 2022
Reporter: aharfoot | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: minor | Component: Installer
Version: | Keywords:
When I install QGIS LTR 3.22.4 using the package based installer
(individual packages, not the meta-package) along with GRASS 7.8 and run
the C:\OSGeo4W\bin\qgis-ltr-bin.exe, the GRASS processing provider is
broken, and trying to run any GRASS processing tool gives the following
error:
''This algorithm cannot be run :-(
The specified GRASS 7 folder "C:\OSGeo4W\bin\bin" does not contain a valid
set of GRASS 7 modules. Please, go to the Processing settings dialog, and
check that the GRASS 7 folder is correctly configured''
The same behaviour is not seen with the standalone QGIS installer.
From #47163 I can see that this message is returned by Grass7Utils.py, and
after some exploration I discovered that this is because the GISBASE
environment variable is not set.
If QGIS is launched via the batch file: C:\OSGeo4W\bin\qgis-ltr.bat, then
GISBASE is correctly set and the GRASS processing tool function correctly.
The OSGeo4W package based installer creates a Windows shortcut that points
to the C:\OSGeo4W\bin\qgis-ltr-bin.exe, and therefore when this is run,
the bug exhibits itself.
**Steps to reproduce the issue**
With the OSGeo4W package installer, install QGIS LTR 3.22.4 along with
GRASS 7.8 (7.8.7-1) on MS Windows. Load QGIS via the Start Menu shortcut.
In QGIS, open the Processing panel and double click on a tool from the
GRASS provider.
Check the status of the GISBASE environment variable through the QGIS
python console by executing:
os.environ['GISBASE']
**Environment:**
QGIS: 3.22.4
GRASS: 7.8.7-1
OS: Windows 10 64bit
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/734>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
