[Osgeo4w-trac] [osgeo4w] #715: ssl.SSLError: A failure in the SSL library occurred (_ssl.c:1129)
    trac_osgeo4w at osgeo.org
    Wed May  4 10:05:04 PDT 2022
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Comment (by jef):
 Grmpf, tried the patch without success.  `prgcloud.com` still fails.  On a
 closer look this is (meanwhile?) because its certificate is for
 `www.prgcloud.com`.  `www.prgcloud.com` and `www.python.org` work fine.
 #!python
 import ssl
 import socket
 import urllib.request
 for i in ['prgcloud.com', 'www.prgcloud.com', 'www.python.org']:
   try:
     socketHandler = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
     socketWrapped =
 ssl.create_default_context().wrap_socket(socketHandler, server_hostname=i)
     socketWrapped.connect((i, 443))
     print(f"ssl {i}: OK")
   except Exception as e:
     print(f"ssl {i}: FAIL {e}")
   try:
     response = urllib.request.urlopen(f'https://{i}/')
     html = response.read()
     print(f"urllib {i}: OK")
     print(f"urllib {i}: FAIL {e}")
 results in:
 C:\OSGeo4W>python3 test.py
 ssl prgcloud.com: FAIL A failure in the SSL library occurred (_ssl.c:1129)
 urllib prgcloud.com: FAIL <urlopen error A failure in the SSL library
 occurred (_ssl.c:1129)>
 ssl www.prgcloud.com: OK
 urllib www.prgcloud.com: OK
 ssl www.python.org: OK
 urllib www.python.org: OK
 Guess the fix for #696 cured this too.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/715#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
