[Osgeo4w-trac] [osgeo4w] #715: ssl.SSLError: A failure in the SSL library occurred (_ssl.c:1129)
OSGeo4W trac_osgeo4w at osgeo.org
Thu May 5 02:04:56 PDT 2022
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  closed
Priority:  major        |   Component:  Package
 Version:               |  Resolution:  fixed
Keywords:               |
Comment (by hellik):
 Replying to [comment:15 hellik]:
 > looking at https://trac.osgeo.org/osgeo4w/ticket/696#comment:2
 > import os
 > os.getenv("SSL_CERT_FILE")
 > os.getenv("SSL_CERT_DIR")
 > cert_filet = os.getenv("SSL_CERT_FILE")
 > cert_dirt = os.getenv("SSL_CERT_DIR")
 > print(cert_filet)
 > print(cert_dirt)
 > results in
 > # Python Console
 > # Use iface to access QGIS API interface or type help(iface) for more
 info
 > # Security warning: typing commands from an untrusted source can harm
 your computer
 exec(Path('C:/Users/hkmyr/AppData/Local/Temp/tmpkhsda6a5.py').read_text())
 > C:\OSGeo4W\bin\curl-ca-bundle.crt
 > C:\OSGeo4W\apps\openssl\certs
 **C:\OSGeo4W\bin\curl-ca-bundle.crt** is there
 **C:\OSGeo4W\apps\openssl\certs** is an empty folder here
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/715#comment:16>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
