[Osgeo4w-trac] [osgeo4w] #715: ssl.SSLError: A failure in the SSL library occurred (_ssl.c:1129)
OSGeo4W trac_osgeo4w at osgeo.org
Thu May 5 08:45:31 PDT 2022
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  closed
Priority:  major        |   Component:  Package
 Version:               |  Resolution:  fixed
Keywords:               |
Comment (by andreaerdna):
 The OS version of my system is reported in QGIS About window as "Windows
 10 Version 1903".
 The latest script executed in the Python console of QGIS 3.24.2 or 3.22.6
 launched from the shortcut (.exe) returns:
 SSL_CERT_FILE:None
 ssl www.osgeo.org: FAIL A failure in the SSL library occurred
 (_ssl.c:1129)
 urllib www.osgeo.org: FAIL <urlopen error A failure in the SSL library
 occurred (_ssl.c:1129)>
 ssl www.python.org: OK
 urllib www.python.org: OK
 The same script executed in the Python console of QGIS 3.24.2 or 3.22.6
 launched from the .bat batch files, or in the OSGeo4W (v2) Shell, returns:
 SSL_CERT_FILE:C:\OSC726~1\bin\curl-ca-bundle.crt
 (_ssl.c:1129)
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/715#comment:19>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
