[Osgeo4w-trac] [osgeo4w] #738: grass8 needs proj82-runtime
OSGeo4W trac_osgeo4w at osgeo.org
Tue May 10 02:08:16 PDT 2022
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Description changed by andreaerdna:
Old description:
> Installing GRASS 8 (grass8 8.0.1-2), without also installing QGIS, leads
> to the following error unsuccessfully trying to launch it:
> Sto avviando GRASS GIS...
> ATTENZIONE: Il locking concorrente del mapset non è supportato in
> Windows.
> Eliminando i file temporanei...
>           __________  ___   __________    _______________
>          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
>         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
>        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
>        \____/_/ |_/_/  |_/____/____/   \____/___//____/
> Benvenuto in GRASS GIS8.0.1
> Homepage di GRASS GIS:                   https://grass.osgeo.org
> Questa versione è eseguita tramite:      Command Prompt
> (C:\WINDOWS\system32\cmd.exe)
> Help is available with the command:      g.manual -i
> VIsualizza i termini di licenza con:     g.version -c
> See citation options with:               g.version -x
> Se necessario, riavvia la GUI con:       g.gui wxpython
> Per uscire digitare:                     exit
> Sto avviando <wxpython> GUI in background, attendere prego...
> Microsoft Windows [Versione 10.0.18362.778]
> (c) 2019 Microsoft Corporation. Tutti i diritti sono riservati.
> C:\Users\giudiceandrea\Documents>wxnviz.py: Could not load grass_g3d.8.0.
> wxdigit.py: Could not load grass_vector.8.0.
> Traceback (most recent call last):
>   File "C:\OSC726~1\apps\Python39\lib\site-packages\wx\core.py", line
> 3407, in <lambda>
>     lambda event: event.callable(*event.args, **event.kw) )
>   File "C:\OSC726~1\apps\grass\grass80\gui\wxpython\wxgui.py", line 88,
> in show_main_gui
>     mainframe = GMFrame(parent=None, id=wx.ID_ANY,
> workspace=self.workspaceFile)
>   File "C:\OSC726~1\apps\grass\grass80\gui\wxpython\lmgr\frame.py", line
> 156, in __init__
>     self._createConsole(self.notebook)
> 379, in _createConsole
>     self.goutput = GConsoleWindow(
>   File "C:\OSC726~1\apps\grass\grass80\gui\wxpython\gui_core\goutput.py",
> line 127, in __init__
>     self.cmdPrompt = GPromptSTC(
>   File "C:\OSC726~1\apps\grass\grass80\gui\wxpython\gui_core\prompt.py",
> line 155, in __init__
>     GPrompt.__init__(self, parent=parent, giface=giface,
> menuModel=menuModel)
> line 57, in __init__
>     self.mapList = self._getListOfMaps()
> line 114, in _getListOfMaps
>     result["raster"] = grass.list_strings("raster")
>   File "C:\OSC726~1\apps\grass\grass80\etc\python\grass\script\core.py",
> line 1462, in list_strings
>     for line in read_command(
> line 606, in read_command
>     return handle_errors(returncode, stdout, args, kwargs)
> line 429, in handle_errors
>     raise CalledModuleError(module=module, code=code,
> returncode=returncode)
> grass.exceptions.CalledModuleError: Module run `g.list --q -m
> type=raster` ended with an error.
> The subprocess ended with a non-zero return code: 3221225781. See errors
> above the traceback or in the error output.
> It seems to me this is due to the the fact that the package
> proj82-runtime is not listed in the grass8 dependencies, while
> proj_8_2.dll is needed by libgrass_gproj.8.0.dll.
> Manually installing proj82-runtime fixes the issue and then it is
> possible to successfully launch GRASS 8.
> When qgis* is installed alongside grass8, then the issue doesn't occur
> because proj82-runtime is automatically installed as a dependency of
> python3-pyproj (why pyproj needs PROJ 8 and not PROJ 9?) which in turns
> is automatically installed as a dependency of qgis*.
New description:
 Installing GRASS 8 (grass8 8.0.1-3) [, without also installing QGIS,]
 leads to the following error unsuccessfully trying to launch it:
 ATTENZIONE: Il locking concorrente del mapset non è supportato in Windows.
 3407, in <lambda>
   File "C:\OSC726~1\apps\grass\grass80\gui\wxpython\wxgui.py", line 88, in
 show_main_gui
 156, in __init__
 grass.exceptions.CalledModuleError: Module run `g.list --q -m type=raster`
 It seems to me this is due to the the fact that the package proj82-runtime
 is not listed in the grass8 dependencies, while proj_8_2.dll is needed by
 Manually installing proj82-runtime fixes the issue and then it is possible
 [When qgis* is installed alongside grass8, then the issue doesn't occur
 python3-pyproj (why pyproj needs PROJ 8 and not PROJ 9?) which in turns is
 automatically installed as a dependency of qgis*.]
 EDIT: proj82-runtime is no longer listed as a dependency of
 python3-pyproj, so it is no longer automatically installed by any qgis*
 package.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/738#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
