[Osgeo4w-trac] [osgeo4w] #761: gdal-dev: ImportError: DLL load failed while importing _gdal
OSGeo4W trac_osgeo4w at osgeo.org
Tue Sep 27 01:57:19 PDT 2022
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  closed
Priority:  critical     |   Component:  Package
 Version:               |  Resolution:  fixed
Keywords:               |
Comment (by andreaerdna):
 It seems adding
 call "%OSGEO4W_ROOT%\bin\gdal-dev-env.bat"
 in %OSGEO4W_ROOT%\apps\gdal-dev\Scripts\gdal_merge.bat
 fixes the issue for GDAL Merge processing algorithm.
 gdal_merge.bat:
 @echo off
 call "%OSGEO4W_ROOT%\bin\o4w_env.bat"
 python "%OSGEO4W_ROOT%\apps\gdal-dev\Scripts\gdal_merge.py" %*
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/761#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
