[Osgeo4w-trac] [osgeo4w] #783: python3-statsmodels: truncated filenames
trac_osgeo4w at osgeo.org
Mon Apr 17 02:06:32 PDT 2023
Reporter: tdanckaert | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Keywords:
With current python3-statsmodels 0.12.1-1, `import statsmodels.api` fails
with an `ImportError`:
{{{ImportError: cannot import name '_univariate_diffuse' from
'statsmodels.tsa.statespace._filters' (C:\OSGEO4~1.22\apps\Python39\lib
\site-packages\statsmodels\tsa\statespace\_filters\__init__.py)}}}
Closer inspection reveals that the file for module `_univariate_diffuse`
is there, but it is a native extension module with an incomplete filename:
the file is simply called `_univariate_diffuse.cp39-win` (or similar,
recalling from memory). Renaming the file to the full
`_univariate_diffuse.cp39-win_amd64.pyd` fixes this particular import, but
the we hit some other files with the same issue.
In the end, I had to rename a number of native extension modules with
truncated file names in `statsmodels.tsa.statespace` and its `_filters`
and `_smoothers` subpackages, in order to be able to import the package.
Possibly some filename length limit in the build process?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/783>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
