[Osgeo4w-trac] [osgeo4w] #861: OSGeo4W Setup fails to completely uninstall python3-pyarrow 0.0.0-1
    trac_osgeo4w at osgeo.org
    Sat Dec  7 03:34:32 PST 2024
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Description changed by andreaerdna:
Old description:
> After uninstalling python3-pyarrow 0.0.0-1 using OSGeo4W Setup, the
> {{{pyarrow}}} folder, containing a  is still present in
> {{{apps\Python312\Lib\site-packages\}}}
> This prevents the user to workaround #860 in order to make geopandas and
> pandas correctly work.
New description:
 {{{pyarrow}}} folder is still present in {{{apps\Python312\Lib\site-
 packages\}}}.
 This prevents the user to workaround the side effects of #860 in order to
 make geopandas and pandas correctly work.
 Removing the {{{pyarrow}}} folder in {{{apps\Python312\Lib\site-
 packages\}}} is needed in order to workaround the side effects of #860 and
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/861#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
