[Osgeo4w-trac] [osgeo4w] #819: Cannot import both pyarrow and osgeo in OSGeo4W shell
trac_osgeo4w at osgeo.org
Mon Mar 11 10:03:45 PDT 2024
Reporter: jontwo | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Keywords:
The latest version of dask was causing an import error, but on further
investigation it turns out that pyarrow and GDAL cannot be installed at
the same time.
Repro case: importing on the command line, both libraries can be imported
individually, but not together. You get a different error depending on the
import order.
c:\>python -c "import pyarrow"
c:\>python -c "import osgeo"
c:\>python -c "import pyarrow;import osgeo"
File "C:\OSGeo4W\apps\Python39\lib\site-packages\osgeo\__init__.py",
line 30, in swig_import_helper
return importlib.import_module(mname)
File "C:\OSGeo4W\apps\Python39\lib\importlib\__init__.py", line 127, in
import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in
_find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 666, in _load_unlocked
File "<frozen importlib._bootstrap>", line 565, in module_from_spec
File "<frozen importlib._bootstrap_external>", line 1173, in
create_module
File "<frozen importlib._bootstrap>", line 228, in
_call_with_frames_removed
ImportError: DLL load failed while importing _gdal: The specified
procedure could not be found.
During handling of the above exception, another exception occurred:
File "<string>", line 1, in <module>
line 35, in <module>
_gdal = swig_import_helper()
line 32, in swig_import_helper
return importlib.import_module('_gdal')
import_module
ModuleNotFoundError: No module named '_gdal'
c:\>python -c "import osgeo;import pyarrow"
File "C:\OSGeo4W\apps\Python39\lib\site-packages\pyarrow\__init__.py",
line 65, in <module>
import pyarrow.lib as _lib
ImportError: DLL load failed while importing lib: The specified procedure
could not be found.
System information:
QGIS version
3.34.4-Prizren
QGIS code revision
decd43dc
Qt version
5.15.3
Python version
3.9.18
GDAL/OGR version
3.8.4
PROJ version
9.3.1
EPSG Registry database version
v10.098 (2023-11-24)
GEOS version
3.12.1-CAPI-1.18.1
SQLite version
3.41.1
PDAL version
2.6.0
PostgreSQL client version
16.1
SpatiaLite version
5.1.0
QWT version
6.1.6
QScintilla2 version
2.13.4
OS version
Windows 10 Version 2009
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/819>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
