[Osgeo4w-trac] [osgeo4w] #832: PROJ_LIB environment variable is deprecated
    trac_osgeo4w at osgeo.org
    Wed May  1 18:08:16 PDT 2024
Reporter:  Mike Taves  |      Owner:  osgeo4w-dev@…
    Type:  defect      |     Status:  new
Priority:  normal      |  Component:  Package
 Version:              |   Keywords:
 When using one of the PROJ utilities from an OSGeo4W Shell, a
 DeprecationWarning message is shown at the top:
 C:\OSGeo4W>proj
 DeprecationWarning: PROJ_LIB environment variable is deprecated, and will
 be removed in a future release. You are encouraged to set PROJ_DATA
 instead.
 Rel. 9.4.0, March 1st, 2024
 usage: proj [-bdeEfiIlmorsStTvVwW [args]] [+opt[=arg] ...] [file ...]
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/832>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
