[Osgeo4w-trac] [osgeo4w] #831: gdal-dev-tiledb package is not up-to-date and gives errors
OSGeo4W trac_osgeo4w at osgeo.org
Thu May 2 05:40:18 PDT 2024
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  closed
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:  wontfix
Keywords:               |
Comment (by andreaerdna):
 Replying to [comment:1 jef]:
 > Uninstall gdal-dev-tiledb
 Does this means that the TileDB GDAL plugin will no longer work with GDAL
 dev 3.10? If so, shouldn't it be removed from the repository or not listed
 among the available packages?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/831#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
