[Osgeo4w-trac] [osgeo4w] #855: Missing c-blosc dependency for GDAL
OSGeo4W trac_osgeo4w at osgeo.org
Mon Oct 28 06:53:28 PDT 2024
Reporter:  rouault      |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Comment (by jratike80):
 For checking which compressions are built-in and supported by the GDAL
 version that is in use, do
 gdalinfo --format zarr
   <Option name="COMPRESS" type="string-select" description="Compression
 method" default="NONE">
     <Value>NONE</Value>
     <Value>ZLIB</Value>
     <Value>GZIP</Value>
     <Value>LZMA</Value>
     <Value>ZSTD</Value>
     <Value>LZ4</Value>
   </Option>
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/855#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
