[Osgeo4w-trac] [osgeo4w] #850: poppler/GDAL: image dithering when transforming vector PDF to raster image
trac_osgeo4w at osgeo.org
Thu Sep 5 03:17:15 PDT 2024
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Keywords:
As reported at https://github.com/OSGeo/gdal/issues/10595.
If it is not possible to fix the OSGeo4W poppler 24.04.0 build, or in the
meantime that it will be fixed, I propose to downgrade the OSGeo4W poppler
package to the previous version and rebuild gdal and other dependent
packages in order to avoid the reported issue.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/850>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
