[Osgeo4w-trac] [osgeo4w] #852: Vulnerable OpenSSL v3.0.14 DLLs exist in OSGEO4W install
trac_osgeo4w at osgeo.org
Wed Sep 11 06:03:30 PDT 2024
Reporter: ascottwwf | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Keywords:
The latest QGIS OSGeo4W_v2 installer installs 4 OpenSSL v3.0.14 DLLs, this
version is vulnerable to the following CVEs (https://openssl-
library.org/news/vulnerabilities-3.0/index.html):
- CVE-2024-5535 - SSL_select_next_proto buffer overread [Low severity]
26 June 2024
- CVE-2024-6119 - Possible denial of service in X.509 name checks
[Moderate severity] 03 September 2024
Evidence of my findings (using the following PowerShell):
$files = 'libcrypto*.dll','libssl*.dll',’*openssl.exe’
cd 'C:\Program Files\OSGeo4W_v2\'
Get-ChildItem $($files) -Recurse -Force -ErrorAction SilentlyContinue |
Select-Object * -ExpandProperty VersionInfo | Sort-Object
ProductVersion,FileVersionRaw,Filename | Select-Object
ProductVersion,FileVersionRaw,Filename,FileDescription,CompanyName,LegalCopyright
| ft -auto
Results:
ProductVersion FileVersionRaw FileName
FileDescription CompanyName
LegalCopyright
3.0.14 3.0.14.0 C:\Program
Files\OSGeo4W_v2\apps\Python312\DLLs\libcrypto-3-x64.dll OpenSSL library
The OpenSSL Project, https://www.openssl.org/ Copyright 1998-2024 The
OpenSSL Authors. All rights reserved.
Files\OSGeo4W_v2\apps\Python312\DLLs\libssl-3-x64.dll OpenSSL library
Files\OSGeo4W_v2\bin\libcrypto-3-x64.dll OpenSSL library
Files\OSGeo4W_v2\bin\libssl-3-x64.dll OpenSSL library
OpenSSL released version 3.0.15 on Tuesday 3rd September to fix both of
the above CVEs.
Please can the OpenSSL DLLs included in OSGeo4W_v2 be updated, so they use
the latest OpenSSL v3.0.15 version (or v3.1.7, v3.2.3 or v3.3.2)?
Thanks in advance,
\\Adrian Scott
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/852>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
