[Osgeo4w-trac] [osgeo4w] #878: HAS_KDE_QT5_PDF_TRANSFORM_FIX, HAS_KDE_QT5_SMALL_CAPS_FIX and HAS_KDE_QT5_FONT_STRETCH_FIX CMAKE flags
OSGeo4W trac_osgeo4w at osgeo.org
Tue Apr 15 12:24:02 PDT 2025
Reporter:  andreaerdna  |      Owner:  osgeo4w-dev@…
    Type:  enhancement  |     Status:  new
Priority:  normal       |  Component:  Package
 Version:               |   Keywords:
 If the OSGeo4W 's Qt5 builds are built from the KDE's maintained 5.15 fork
 containing the "PDF brush transform", the
 "QFont::SmallCaps" the "QFont stretch" fixes, then could the
 https://github.com/qgis/QGIS/blob/db3ed8627a05c5c69c55625c18a57e49db17072e/CMakeLists.txt#L558-L560
 be set for the OSGeo4W's QGIS builds in order to enable the
 features introduced with https://github.com/qgis/QGIS/pull/45946,
 https://github.com/qgis/QGIS/pull/45887 and
 https://github.com/qgis/QGIS/pull/45827?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/878>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
