[Osgeo4w-trac] [osgeo4w] #879: ogrinfo (gdal-dev) fails: MSVCP140.ddl error probably related to proj
OSGeo4W trac_osgeo4w at osgeo.org
Fri Apr 25 07:40:00 PDT 2025
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Comment (by andreaerdna):
 Actually the crssync.exe, untwine.exe and pdal_wrench.exe errors occur
 also for qgis and qgis-ltr if proj9-runtime 9.6.0-1 is installed, while
 they don't occur after downgrading proj9-runtime from 9.6.0-1 to 9.5.1-1.
 Also SAGA-GUI fails to start if proj9-runtime 9.6.0-1 is installed, while
 it succeeds after downgrading proj9-runtime from 9.6.0-1 to 9.5.1-1.
 I guess also GRASS-GIS could be affected by the same issue.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/879#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
