[Osgeo4w-trac] [osgeo4w] #868: python3-rasterio broken in latest release
OSGeo4W trac_osgeo4w at osgeo.org
Mon Feb 3 16:40:34 PST 2025
Reporter:  Christina Ratcliff  |       Owner:  osgeo4w-dev@…
    Type:  defect              |      Status:  new
Priority:  critical            |   Component:  Package
 Version:                      |  Resolution:
Keywords:                      |
Comment (by Christina Ratcliff):
 I have tried to install {{{python3-rasterio 1.4.3-1}}} with both the
 OSGeo4W Network installer and the QGIS standalone and get the same error.
 From existing install using OsGeo4W on Windows 10
  ||QGIS  3.40.2-Bratislava || GDAL  3.9.3 ||
  ||LTR   3.34.14-Prizren   || GDAL  3.9.3 ||
 From Standalone Installer on Windows Server 2016 VM with fresh QGIS
 installs.
 I am using [https://trac.osgeo.org/osgeo4w/wiki/CommandLine OSGeo4W
 command line] to install the packages.
 {{{"%OSGEO4W_ROOT%\bin\osgeo4w-setup.exe" -q -b -A -k -n -s
 http://download.osgeo.org/osgeo4w/v2 -P python3-geopandas -P
 python3-rasterio -P python3-fiona}}}
 {{{python3-rasterio 1.3.10-1}}} is compatible with the above. Is there a
 switch for using the previous version when using the command line?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/868#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
