[Osgeo4w-trac] [osgeo4w] #867: python3-fiona broken in latest release
trac_osgeo4w at osgeo.org
Mon Feb 3 16:55:31 PST 2025
Reporter: Christina Ratcliff | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: critical | Component: Package
Version: | Resolution:
Keywords: |
Comment (by Christina Ratcliff):
I have tried to install {{{python3-fiona 1.10.1-1}}} with both the OSGeo4W
Network installer and the QGIS standalone and get the same error.
From existing install using OsGeo4W on Windows 10
|| ||=GDAL=||
||QGIS 3.40.2-Bratislava || 3.9.3||
||LTR 3.34.14-Prizren || 3.9.3||
From Standalone Installer on Windows Server 2016 VM with fresh QGIS
installs.
|| ||=GDAL=||=GDAL309-runtime=||=GDAL310-runtime=||
||QGIS 3.40.2-Bratislava ||3.9.3||3.9.3-2||3.10.1-1||
||LTR 3.34.14-Prizren ||3.9.3||3.9.3-2||3.10.1-1||
I am using [https://trac.osgeo.org/osgeo4w/wiki/CommandLine OSGeo4W
command line] to install the packages.
{{{"%OSGEO4W_ROOT%\bin\osgeo4w-setup.exe" -q -b -A -k -n -s
http://download.osgeo.org/osgeo4w/v2 -P python3-geopandas -P
python3-rasterio -P python3-fiona}}}
{{{python3-fiona 1.9.6-3}}} is compatible with the above. Is there a
switch for using the previous version when using the command line?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/867#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
