[Osgeo4w-trac] [osgeo4w] #878: HAS_KDE_QT5_PDF_TRANSFORM_FIX, HAS_KDE_QT5_SMALL_CAPS_FIX and HAS_KDE_QT5_FONT_STRETCH_FIX CMAKE flags
OSGeo4W trac_osgeo4w at osgeo.org
Sat Jun 21 04:49:17 PDT 2025
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  closed
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:  fixed
Keywords:               |
Comment (by andreaerdna):
 Hi @jef, please have a look at
 https://github.com/qgis/QGIS/issues/62273#issuecomment-2993535300.
 I think it should be possible to workaround the issue for the Qt5 builds
 just removing the HAS_KDE_QT5_PDF_TRANSFORM_FIX build flag. Anyway the
 issue will still occur for the Qt6 builds.
 P.S. there is no need to set the HAS_KDE_QT5_PDF_TRANSFORM_FIX,
 HAS_KDE_QT5_SMALL_CAPS_FIX and HAS_KDE_QT5_FONT_STRETCH_FIX CMAKE flag for
 the Qt6 builds: the features (and issue) are in place  for QGIS built
 against Qt >= 6.3.0 even if such flags are not set (they have meaning only
 for Qt5 builds). So they can be removed for the Qt6 builds.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/878#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
