[Osgeo4w-trac] [osgeo4w] #870: qgis-dev: crssync.exe fails in postinstall for missing gdal310.dll
trac_osgeo4w at osgeo.org
Mon Mar 3 09:57:52 PST 2025
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: normal | Component: Package
Version: | Resolution: worksforme
Keywords: |
Comment (by andreaerdna):
Actually the description of the issue was inaccurate.
I had both qgis and qgis-dev installed at the same time. I had updated
qgis-dev and gdal-dev without also updating qgis and gdal, since I know
qgis-dev is build against gdal-dev, not gdal.
The qgis-dev didn't install properly (crssync.exe failed) and it didn't
start with the following error:
qgis-dev-bin.exe - Entry Point Not Found
The procedure entry point
??GlobalParams@@YAEAAV0EAAPEAD at Z could not be located in the dynamic link
library
C:\OSGeo4W\bin\gdal310.dll.
I removed gdal310.dll in order to ensure it was the cause of the issue,
and then I found that qgis-dev depends on gdal-dev but it also depends on
pdalcpp which depends on gdal.
I think it would be better if qgis-dev used a dedicated pdalcpp built
against gdaldev (like qgis-dev itself) and not the one built against gdal.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/870#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
