[Osgeo4w-trac] [osgeo4w] #876: saga 9.7.1-1 fails to start (MSVCP140.dll error)
trac_osgeo4w at osgeo.org
Sun Mar 30 03:19:06 PDT 2025
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: critical | Component: Package
Version: | Resolution:
Keywords: |
Comment (by andreaerdna):
Why GRASS-GIS and SAGA-GIS (and other ones) executable don't use the
msvcp140.dll shipped by OSGeo4W with the msvcrt2019 package (shouldn't it
be named msvcrt2022)? Is there a way to enforce the use of the one shipped
by OSGeo4W instead of the one installed in the system (apart from copying
the msvcp*.dll in the same folder of the executable)?
It looks like on some Windows 10 versions also pdal_wrench.exe
https://github.com/qgis/QGIS/issues/61222 and untwine.exe
https://github.com/qgis/QGIS/issues/61222#issuecomment-2760570138 have the
same issue also disrupting the Point Cloud functionalities in QGIS.
The msvcp140.dll 14.32.31332.0 in my system32 folder has the creation and
last modified date June 10th, 2022, and it was almost certainly installed
by the latest Microsoft Visual C++ 2015-2022 Redistributable (x64) -
14.32.31332 installed in my system.
If there is no way to enforce the use of the one shipped by OSGeo4W
instead of the one installed in the system, then maybe the Setup program
should check the msvc version installed in the system and either trigger a
newer version installation or warn the user, or maybe a note should be put
in the Windows download page about the minimum msvc version needed for
Windows 10/11.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/876#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
