[Osgeo4w-trac] [osgeo4w] #894: Uninstalling python3-shapely package doesn't completely removes all related folders and files and then QGIS starts without Python support
trac_osgeo4w at osgeo.org
Wed Oct 8 14:46:01 PDT 2025
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Resolution:
Keywords: |
Comment (by andreaerdna):
After uninstalling python3-shapely (ensuring that no instances of QGIS are
running), there is still a {{{shapely}}} folder in {{{\apps\Python312\Lib
\site-packages\}}}.
Such folder contains the following files and folders:
Directory di C:\OSGeo4W_V2_E\apps\Python312\Lib\site-
packages\shapely\algorithms
08/10/2025 23:28 <DIR> .
08/10/2025 23:28 <DIR> ..
08/10/2025 23:27 <DIR> __pycache__
0 File 0 byte
packages\shapely\algorithms\__pycache__
08/10/2025 23:27 <DIR> .
08/10/2025 23:27 <DIR> ..
08/10/2025 23:27 1.385 cga.cpython-312.pyc
08/10/2025 23:27 2.514 _oriented_envelope.cpython-312.pyc
08/10/2025 23:27 172 __init__.cpython-312.pyc
3 File 4.071 byte
packages\shapely\geometry
0 File 0 byte
packages\shapely\geometry\__pycache__
08/10/2025 23:27 44.551 base.cpython-312.pyc
08/10/2025 23:27 2.149 collection.cpython-312.pyc
08/10/2025 23:27 4.947 geo.cpython-312.pyc
08/10/2025 23:27 7.687 linestring.cpython-312.pyc
08/10/2025 23:27 4.229 multilinestring.cpython-312.pyc
08/10/2025 23:27 3.937 multipoint.cpython-312.pyc
08/10/2025 23:27 4.872 multipolygon.cpython-312.pyc
08/10/2025 23:27 5.521 point.cpython-312.pyc
08/10/2025 23:27 15.548 polygon.cpython-312.pyc
08/10/2025 23:27 947 __init__.cpython-312.pyc
10 File 94.388 byte
packages\shapely\__pycache__
08/10/2025 23:27 9.071 affinity.cpython-312.pyc
08/10/2025 23:27 41.375 constructive.cpython-312.pyc
08/10/2025 23:27 8.328 coordinates.cpython-312.pyc
08/10/2025 23:27 3.384 coords.cpython-312.pyc
08/10/2025 23:27 22.200 creation.cpython-312.pyc
08/10/2025 23:27 4.256 decorators.cpython-312.pyc
08/10/2025 23:27 3.508 errors.cpython-312.pyc
08/10/2025 23:27 14.020 io.cpython-312.pyc
08/10/2025 23:27 7.938 linear.cpython-312.pyc
08/10/2025 23:27 11.000 measurement.cpython-312.pyc
08/10/2025 23:27 35.846 predicates.cpython-312.pyc
08/10/2025 23:27 18.258 set_operations.cpython-312.pyc
08/10/2025 23:27 21.542 strtree.cpython-312.pyc
08/10/2025 23:27 1.275 _enum.cpython-312.pyc
08/10/2025 23:27 27.204 _geometry.cpython-312.pyc
08/10/2025 23:27 19.050 _ragged_array.cpython-312.pyc
08/10/2025 23:27 549 _version.cpython-312.pyc
08/10/2025 23:27 1.149 __init__.cpython-312.pyc
18 File 249.953 byte
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/894#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
