[Osgeo4w-trac] [osgeo4w] #894: Uninstalling python3-shapely package doesn't completely removes all related folders and files and then QGIS starts without Python support
OSGeo4W trac_osgeo4w at osgeo.org
Thu Oct 9 16:51:57 PDT 2025
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Comment (by andreaerdna):
 I'm using the "Setup" shortcut link (which points to setup.bat) in the
 Windows Start menu.
 Please have a look at the screen recording available at
 https://drive.google.com/file/d/1vWwhwj6YIwDnNx9XrqaCQxOl-cbRxBDH/view
 that shows:
 - QGIS starting correctly without python3-shapely
 - QGIS starting correctly after python3-shapely is installed using Setup
 - QGIS throwing the error {{{AttributeError: module 'shapely.geometry' has
 no attribute 'base'}}} at startup
 - QGIS starting correctly after removing the leftover "shapely" folder in
 {{{\apps\Python312\Lib\site-packages\}}}
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/894#comment:7>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
