[Osgeo4w-trac] [osgeo4w] #893: New OSGeo4W installer does not detect existing QGIS installations
OSGeo4W trac_osgeo4w at osgeo.org
Tue Sep 30 10:31:52 PDT 2025
Reporter:  toto71    |      Owner:  osgeo4w-dev@…
    Type:  defect    |     Status:  new
Priority:  critical  |  Component:  Installer
 Version:            |   Keywords:
 I recently downloaded the new OSGeo4W Network Installer.
 When I run the file osgeo4w-setup.exe as administrator, it no longer
 recognizes the existing installations of QGIS and other libraries that I
 previously installed with the older version of osgeo4w-setup.exe.
 As a result, I no longer have the option to update them because they don’t
 appear in the “Select Packages to Install” list, as if QGIS were not
 installed on my PC.
 However, I actually have multiple versions of QGIS installed.
 Is this issue solvable?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/893>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
