[Osgeo4w-trac] [osgeo4w] #923: SAGA: Function GDALRegister ... did not register a driver ... (it needs to be built against GDAL 3.13)
OSGeo4W trac_osgeo4w at osgeo.org
Tue May 19 05:56:53 PDT 2026
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  closed
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:  fixed
Keywords:               |
Comment (by andreaerdna):
 With the latest saga 9.12.3-1 the SAGA processing algorithms (e.g. "Basic
 Terrain Analysis") fail to properly generate raster outputs (or QGIS is
 not able to open them), while vector output are correctly generated.
 Last lines of "Basic Terrain Analysis" algorithm's log:
 Loading resulting layers
 The following layers were not correctly generated.
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/18ded90fea7f49f88f3d943718ed1a1f/SLOPE.sdat
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/3144c89ce7804110b1e6d7a05f83ed5e/VCURV.sdat
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/3363b9fe4313475dbc512b0d418d181e/CONVERGENCE.sdat
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/58565ac9ecff4a99bd9414e40cd02191/WETNESS.sdat
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/63eb9faf29a04628b5dea9e2e0cd60f8/FLOW.sdat
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/66504b5766104b05a5b66c579f7370d4/ASPECT.sdat
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/744f6f570d1c42f1bf969c5d295e037a/CHNL_DIST.sdat
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/96c68f45c5f742869923d3979b4587b6/RSP.sdat
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/9777bcffc5da4b469b87734a599a86ee/SHADE.sdat
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/c0988a83ae86474f957fa4a64a1b3018/CHNL_BASE.sdat
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/dc56ebe69f794958a4f828c5b61f43f1/SINKS.sdat
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/e0abf4df217a495e88ea1c8f5a3dfcef/HCURV.sdat
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/f5abb311ef0245d2b6b068055a00510d/LSFACTOR.sdat
 C:/Users/Andrea/AppData/Local/Temp/processing_BDsERn/f9fe0c3f614b491caf0b1d3e6d2030ba/VALL_DEPTH.sdat
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/923#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
