[OSGeoJapan-discuss] ms4w-3.0.6のWMSについて
    Jeff McKenna
    jmckenna @ gatewaygeomatics.com
    2012年 11月  8日 (木) 08:28:24 PST
Hello Oba-san,
Regarding the projection error ("Projection library error. no options
found in 'init' file") the best way to solve that is to make sure you
use EPSG:3857 in your mapfile, instead of EPSG:900913 (as 900913 is not
the official EPSG code and therefore is not included in your epsg file
by default).
Thank you for using MS4W.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 12-11-08 7:55 AM, tys wrote:
> 上記のhttp://~~を実行すると
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1">
> <ServiceException>
> msProcessProjection(): Projection library error. no options found in
> 'init' file
> </ServiceException>
> </ServiceExceptionReport>
> のxmlが帰ってきます。
More information about the OSGeoJapan-discuss
