[OSGeoJapan-discuss] Integration of Japanese GIS formats into mainline GDAL ?
    Hiroo Imaki
    hiroo @ angeli.org
    2015年 5月  1日 (金) 08:44:46 PDT
Hi Even,
All players have started talking about this topic. Japanese people are in
the middle of long vacation season and I will restart this conversation
with all contributors the end of second week of May.
I will keep posting.
Thanks for your nice offer and contributions to make this happens!
Hiroo
On Fri, May 1, 2015 at 5:59 AM, Even Rouault <even.rouault @ spatialys.com>
wrote:
> Hi Hiroo,
> OK I let you take the necessary time sort that out. Being completely an
> outsider and not having the "big picture" of the existing formats and how
> historic or up-to-date they are, it is also not clear to me which drivers
> might be of general interest for the Japanese community, as opposed to the
> ones which would really be of very restricted scope of interest.
> (Just a word of caution: as those archives are public, and the new drivers
> are
> included in a distribution of source code that is labelled as X/MIT in its
> LICENSE.TXT file, people could in good faith assume that all the files,
> including the extra drivers are also X/MIT)
> I tried the FGD ogr driver on the file
> https://github.com/msherry/PyXB-1.1.4/blob/master/examples/unicode_jp/data/shift_jis/FG-
> GML-13-RailCL25000-20080331-0001.xml
> (found by googling FG-GML)
> It is not recognized by the driver. Looking more closely, the driver seems
> to
> expect a <GI> element that isn't found in that file. It appears that there
> are
> several versions of FGD GML, right ? The above file is apparently v3 (since
> there's a v3 schema next to it). Perhaps the driver is v4 (or a previous
> version) ? I tried to remove the test for the presence of <GI> but it
> crashes
> later during parsing of dates, apparently not liking the <gml:timePosition>
> element within <lfSpanFr>
> I found this project : http://mizutuu.github.io/jpgisgmlv4togml-converter/
> https://github.com/mizutuu/jpgisgmlv4togml-converter
> It includes the schema for FG-GML v4 and I can't see any reference to the
> <GI>
> element in it either.
> With some trickery related to encoding conversion, I managed to use that
> project to produce a standard GML file that the OGR GML driver handles
> well :
> cat FG-GML-13-RailCL25000-20080331-0001.xml | iconv --from-code=shift-jis
> to-code=utf-8 | sed "s/Shift_JIS/UTF-8/" | python jpgisgml2gml.py > out.gml
> I've also found this site http://nlftp.mlit.go.jp/ksj-e/ and downloaded a
> few
> datasets. Those I tried are not handled by the OGR FGD driver. Some of them
> look like GML with a particular application schema. They are unfortunately
> not
> standard enough for the OGR GML driver to understand them out of the box,
> although I believe it could be tweaked to parse them. Their header look
> like:
> <ksj:Dataset gml:id="A09Dataset"
> xmlns:ksj="http://nlftp.mlit.go.jp/ksj/schemas/ksj-app"
> xmlns:gml="http://www.opengis.net/gml/3.2"
> xmlns:xlink="http://www.w3.org/1999/xlink" xm
> lns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://nlftp.mlit.go.jp/ksj/schemas/ksj-app
> KsjAppSchema-
> A09-v3_1.xsd">
> There's a shapefile next to them, with apparently same content.
> So it appears there's a variety of GML-like formats ;-)
> Even
> > Hi Even,
> > I talk to Yamate-san who has been working on those three drivers. He
> > explained that each driver has little bit different copy right background
> > he need to resolve before he can merge them to the main.
> > The first one, FGD driver, which he wrote for a project and he does not
> > have control on its copy right. So, he would like to leave it at this
> > moment.
> > For the second one, FG-GML driver, he wrote it and he owns its copy right
> > at this moment. But he said he can release with the licence you
> suggested.
> > The last one, FGD ogr driver, which he also wrote and it is highly
> possible
> > he can release it under the MIT licence. But he need to make sure his
> > client can agree on this. So, he said he will contact to his client.
> > So, the last two drivers can be merge into the main GDAL driver. It is
> > little bit confusing background but I am sure we can sort these out.
> > I will let you know when he is ready to work with you.
> > Thanks!
> > Hiroo
> > On Thu, Apr 30, 2015 at 2:26 PM, Hiroo Imaki <hiroo @ angeli.org> wrote:
> > > Hi Even,
> > > I am not the developer but he and I working at a same company. If he
> can
> > > agree on the license and release his efforts, that would be wonderful
> for
> > > all Japanese data uses.
> > > He hesitates writing his message in English. So, I can be a translator
> > > between you guys. I hope no lost in translation!
> > > I will get back to you once I hear from him.
> > > Hiroo
> > > On Thu, Apr 30, 2015 at 10:45 AM, Even Rouault
> > > > wrote:
> > >> Hi,
> > >> Sorry for writing in English, but I don't unfortunately speak
> Japanese.
> > >> I'm one of the GDAL developers.
> > >> I've noticed that there are "un-official" versions of GDAL floating
> > >> around, with
> > >> a few drivers for new Japanese-specific formats. I was wondering if
> > >> there was a
> > >> reason to keep them outside of the official GDAL tree ? Integrating
> them
> > >> into
> > >> mainline GDAL would probably make life of Japanese users easier. GDAL
> > >> has already support for a lof of national specific formats, mainly in
> > >> Europe and
> > >> North America. Would be cool for Asia to join in ;-)
> > >> In a recent discussion thread, the following link is mentionned:
> > >>  https://www.dropbox.com/s/4oyhncknavdk2if/gdal110_test.zip
> > >> I can see that it contains 2 new GDAL drivers ( FGD: Japanese
> > >> Fundamental Geographic Data (.xml) & FG-GML :  Japanese Fundamental
> > >> Geographic Data GML(.xml) ) and one OGR driver (FGD).
> > >> Unfortunatelly there's no author or copyright information in the
> header
> > >> of the
> > >> corresponding source files. Would their author(s) be willing to
> release
> > >> them
> > >> under the X/MIT license and contribute them to the mainline GDAL
> project
> > >> ? Perhaps some test files to write minimalistic regressions tests
> would
> > >> be useful.
> > >> Let me know if I can be useful for anything. I can also help for
> writing
> > >> new
> > >> drivers if needed.
> > >> Best regards,
> > >> Even
> > >> Spatialys - Geospatial professional services
> > >> http://www.spatialys.com
> > >> _______________________________________________
> > >> OSGeoJapan-discuss mailing list
> > >> OSGeoJapan-discuss @ lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/osgeojapan-discuss
> > > Hiroo Imaki
> > > Pacific Spatial Solutions, LLC
> > > 1523 Chatham Colony Ct.
> > > Reston, VA  20190
> > > hiroo.imaki @ pacificspatial.com
> > > http://www.pacificspatial.com
> > > http://www.geopacific.org (GIS info site)
> > > hiroo @ angeli.org (private)
Hiroo Imaki
Reston, VA  20190
HTML$B$NE:IU%U%!%$%k$rJ]4I$7$^$7$?(B...
URL: <http://lists.osgeo.org/pipermail/osgeojapan-discuss/attachments/20150501/b65b9838/attachment-0001.html>
OSGeoJapan-discuss メーリングリストの案内
