[OSGeoJapan-discuss] Integration of Japanese GIS formats into mainline GDAL ?
Ko Nagase
nagase @ georepublic.co.jp
2015年 10月 8日 (木) 05:21:58 PDT
Hi Even,
Sorry for our low activity.
We are still discussing about this topic,
and it may take more time...
(Hopefully, we will take some action in this autumn...)
So, could you wait for a while ?
Regards,
Ko
2015-10-08 18:03 GMT+09:00 Even Rouault <even.rouault @ spatialys.com>:
> Hi all,
> I was wondering if there had been progress on this ? I can see a
> https://github.com/OSGeo-jp/gdal repository, but it doesn't seem to contain
> changes for now.
> Best regards,
> Even
>> Hi Hiroo-san,
>> CC: Akagi-san, Even, list
>> Thanks for your comments.
>> 2015-08-19 9:58 GMT+09:00 Hiroo Imaki <hiroo @ angeli.org>:
>> > Hi Even, Akagi-san, and Ko-san
>> > Ko-san, I am sorry I missed your message you set to the list last month.
>> > I was on vacation and did not check email for a while.
>> > I stepped in this conversation last May and has been talking to those
>> > people who worked on GDAL and OGR drivers for the Japanese data. But I
>> > realized that I am not that useful on this topic (sorry!).
>> Okay, no problem.
>> > Here is what I found so far. For the old drivers (JPGIS driver for vector
>> > data and DEM raster data driver), owners of those agreed on releasing
>> > them with the MIT license. For the JPGIS (GML) vector driver, there is
>> > one more step to release it but it hasn't reached the point to release
>> > it.
>> Okay, thanks for information.
>> I guess that existence(under procedure) JPGIS (GML) v4 vector driver
>> implementation
>> is different from Akagi-san's GML driver improvement, and not conflict
>> with each other.
>> So, I think that both drivers will be available in near future.
>> > Anyway,I totally agree on Akagi-san's comment and people who worked on
>> > this should make efforts for the support of recent format rather than
>> > old formats that are no longer distributed from GSI.
>> > I hope we can release what we already have soon too.
>> Okay.
>> At QGIS Hackfest Tokyo/Hokkaido/Osaka (2015-08-01),
>> Kayama-san renamed Github "qgis-jp" group name to "OSGeo-jp".
>> So, we will be able to work Japanese GDAL adjustment/improvement together
>> after forking "OSGeo/gdal" to "OSGeo-jp/gdal".
>> (I am thinking to prepare JPGIS (GML) v4 dummy data, then put those to
>> the forked repository.)
>> > Akagi-san and Ko-san, great job!!
>> Thank you, too!
>> Regards,
>> Ko
>> > On Tue, Aug 18, 2015 at 4:57 PM, Even Rouault
>> > wrote:
>> >> Hi Minoru,
>> >> > We had an online hackathon about this topic on the same day as QGIS
>> >> > HackFests in Japan (2015-08-01). The purpose was to read FGD (GML)
>> >> > vector data (v4) with the OGR GML driver.
>> >> > I prepared .gfs schema files, then registered them to the GML registry
>> >> > and made a few changes to the GML driver code. Finally, I managed to
>> >> > read FGD (GML) vector data with the driver! See the work branch [1]
>> >> > and the hackpad [2][3] for the details.
>> >> This is cool you managed to use the GML registry mechanism.
>> >> I think however that the changes done in ogrgmldatasource.cpp in this
>> >> branch
>> >> should be amended to restore the previous behaviour when the namespace
>> >> prefix
>> >> is defined in the registry, and the behaviour of the branch when it is
>> >> not defined, so that full control is still available.
>> >> I'd add to the todo list to add a few words to drv_gml.html to mention
>> >> that
>> >> FGD GML v4 is supported in the "Particular GML application schemas"
>> >> section.
>> >> > I think we should make efforts for the support of recent format rather
>> >> > than old formats that are no longer distributed from GSI.
>> >> That makes sense. Sometimes supporting old formats can be of interest
>> >> when people are interested in historic data that isn't available to
>> >> more modern formats, but this is admitedly a particular use case.
>> >> Best regards,
>> >> Even
>> >> > Any comments?
>> >> > [1] https://github.com/minorua/gdal/commits/fgdgml_vector_1.11
>> >> > The branch is based on 1.11 (the current GDAL version of OSGeo4W).
>> >> > [2] https://hackpad.com/JPGISGML-HackFest-2015-XgBUI6qfbGP (In
>> >> > Japanese)
>> >> > [3] https://hackpad.com/JPGIS-GML-Hackathon-2015-iI1ButdfjwX (English
>> >> > summary)
>> >> > Minoru
>> >> > 2015-07-20 23:23 GMT+09:00 Even Rouault <even.rouault @ spatialys.com>:
>> >> > > Ko-san,
>> >> > > Thanks a lot for bringing some light on this.
>> >> > > I've created https://trac.osgeo.org/gdal/ticket/6046 to capture all
>> >> > > findings up to now and trace tasks that I've in mind that should be
>> >> > > completed for integretation into upstream GDAL.
>> >> > > Best regards,
>> >> > > Even
>> >> > >> Hi Even,
>> >> > >> CC: Hiroo-san, Yamate-san, list
>> >> > >> Excuse me for cutting in this topic.
>> >> > >> I am neither the developer nor the player, but I tried mext_gdal
>> >> > >> test version (gdal110_test.zip) at last weekend and probably I
>> >> > >> understood
>> >> > >> some data related part, so I mention some of your question about
>> >> > >> datas.
>> >> > >> (But, if someone find my mistake, please point it out here...)
>> >> > >> 2015-05-01 18:59 GMT+09:00 Even Rouault
>> >> > >> > I tried the FGD ogr driver on the file
>> >> > >> > https://github.com/msherry/PyXB-1.1.4/blob/master/examples/unicod
>> >> > >> > e_jp/d at
>> >> > >> > a/shift_jis/FG- GML-13-RailCL25000-20080331-0001.xml
>> >> > >> > (found by googling FG-GML)
>> >> > >> > It is not recognized by the driver. Looking more closely, the
>> >> > >> > driver
>> >> > >> > seems to expect a <GI> element that isn't found in that file. It
>> >> > >> > appears
>> >> > >> > that there are several versions of FGD GML, right ? The above
>> >> > >> > file is
>> >> > >> > apparently v3 (since there's a v3 schema next to it). Perhaps the
>> >> > >> > driver
>> >> > >> > is v4 (or a previous version) ? I tried to remove the test for
>> >> > >> > the presence of <GI> but it crashes later during parsing of
>> >> > >> > dates, apparently not liking the <gml:timePosition> element
>> >> > >> > within <lfSpanFr>
>> >> > >> There are 2 format types (DLD / GML), 2 recent versions(v3 / v4)
>> >> > >> and 2 (or more) data types (5/10m mesh DEM / General vector data
>> >> > >> .etc)
>> >> > >> in FGD data,
>> >> > >> and current mext_gdal test version seems to support the following
>> >> > >> pair.
>> >> > >> 1. FGD driver: DLD v3 (5/10m mesh DEM)
>> >> > >> 2. FG-GML driver: GML v3 (5/10m mesh DEM)
>> >> > >> 3. FGD driver: DLD v3 (General vector data)
>> >> > >> Above link which you found use GML v3, but it is not 5/10m mesh
>> >> > >> DEM, so you couldn't convert it.
>> >> > >> > I found this project :
>> >> > >> > http://mizutuu.github.io/jpgisgmlv4togml-converter/ /
>> >> > >> > https://github.com/mizutuu/jpgisgmlv4togml-converter
>> >> > >> > It includes the schema for FG-GML v4 and I can't see any
>> >> > >> > reference to
>> >> > >> > the
>> >> > >> > <GI> element in it either.
>> >> > >> > With some trickery related to encoding conversion, I managed to
>> >> > >> > use that
>> >> > >> > project to produce a standard GML file that the OGR GML driver
>> >> > >> > handles
>> >> > >> > well :
>> >> > >> > cat FG-GML-13-RailCL25000-20080331-0001.xml | iconv
>> >> > >> > --from-code=shift-jis
>> >> > >> > -- to-code=utf-8 | sed "s/Shift_JIS/UTF-8/" | python
>> >> > >> > jpgisgml2gml.py >
>> >> > >> > out.gml
>> >> > >> And above GML v4 is not supported (both of 5/10m mesh DEM and
>> >> > >> General vector data) by current mext_gdal for now.
>> >> > >> > I've also found this site http://nlftp.mlit.go.jp/ksj-e/ and
>> >> > >> > downloaded
>> >> > >> > a
>> >> > >> > few datasets. Those I tried are not handled by the OGR FGD
>> >> > >> > driver. Some
>> >> > >> > of them look like GML with a particular application schema. They
>> >> > >> > are
>> >> > >> > unfortunately not standard enough for the OGR GML driver to
>> >> > >> > understand
>> >> > >> > them out of the box, although I believe it could be tweaked to
>> >> > >> > parse
>> >> > >> > them. Their header look like:
>> >> > >> > <ksj:Dataset gml:id="A09Dataset"
>> >> > >> > xmlns:ksj="http://nlftp.mlit.go.jp/ksj/schemas/ksj-app"
>> >> > >> > xmlns:gml="http://www.opengis.net/gml/3.2"
>> >> > >> > xmlns:xlink="http://www.w3.org/1999/xlink" xm
>> >> > >> > lns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> >> > >> > xsi:schemaLocation="http://nlftp.mlit.go.jp/ksj/schemas/ksj-app
>> >> > >> > KsjAppSchema- A09-v3_1.xsd">
>> >> > >> > There's a shapefile next to them, with apparently same content.
>> >> > >> And about above MLIT NLNI(National Land Numerical Information)
>> >> > >> data, it is not FGD data...
>> >> > >> > So it appears there's a variety of GML-like formats ;-)
>> >> > >> Yes, sure...
>> >> > >> If you want to use mext_gdal test data, I just uploaded example
>> >> > >> dummy data
>> >> > >> to the following repository. So, please try to use those files.
>> >> > >> https://github.com/sanak/dev-notes/tree/master/datas/fgd
>> >> > >> (The dummy data location is near by Japan Wakayama prefecture,
>> >> > >> but on the pacific ocean.)
>> >> > >> Regards,
>> >> > >> >> Hi Even,
>> >> > >> >> I talk to Yamate-san who has been working on those three
>> >> > >> >> drivers. He
>> >> > >> >> explained that each driver has little bit different copy right
>> >> > >> >> background he need to resolve before he can merge them to the
>> >> > >> >> main.
>> >> > >> >> The first one, FGD driver, which he wrote for a project and he
>> >> > >> >> does
>> >> > >> >> not
>> >> > >> >> have control on its copy right. So, he would like to leave it at
>> >> > >> >> this
>> >> > >> >> moment.
>> >> > >> >> For the second one, FG-GML driver, he wrote it and he owns its
>> >> > >> >> copy
>> >> > >> >> right at this moment. But he said he can release with the
>> >> > >> >> licence you
>> >> > >> >> suggested.
>> >> > >> >> The last one, FGD ogr driver, which he also wrote and it is
>> >> > >> >> highly possible he can release it under the MIT licence. But he
>> >> > >> >> need to make
>> >> > >> >> sure his client can agree on this. So, he said he will contact
>> >> > >> >> to his
>> >> > >> >> client.
>> >> > >> >> So, the last two drivers can be merge into the main GDAL driver.
>> >> > >> >> It is
>> >> > >> >> little bit confusing background but I am sure we can sort these
>> >> > >> >> out.
>> >> > >> >> I will let you know when he is ready to work with you.
>> >> > >> >> Thanks!
>> >> > >> >> Hiroo
>> >> > >> >> On Thu, Apr 30, 2015 at 2:26 PM, Hiroo Imaki <hiroo @ angeli.org>
>> >> > >> >> wrote:
>> >> > >> >> > Hi Even,
>> >> > >> >> > I am not the developer but he and I working at a same company.
>> >> > >> >> > If he
>> >> > >> >> > can agree on the license and release his efforts, that would
>> >> > >> >> > be wonderful for all Japanese data uses.
>> >> > >> >> > He hesitates writing his message in English. So, I can be a
>> >> > >> >> > translator
>> >> > >> >> > between you guys. I hope no lost in translation!
>> >> > >> >> > I will get back to you once I hear from him.
>> >> > >> >> > Hiroo
>> >> > >> >> > On Thu, Apr 30, 2015 at 10:45 AM, Even Rouault
>> >> > >> >> > > wrote:
>> >> > >> >> >> Hi,
>> >> > >> >> >> Sorry for writing in English, but I don't unfortunately speak
>> >> > >> >> >> Japanese.
>> >> > >> >> >> I'm one of the GDAL developers.
>> >> > >> >> >> I've noticed that there are "un-official" versions of GDAL
>> >> > >> >> >> floating
>> >> > >> >> >> around, with
>> >> > >> >> >> a few drivers for new Japanese-specific formats. I was
>> >> > >> >> >> wondering if
>> >> > >> >> >> there was a
>> >> > >> >> >> reason to keep them outside of the official GDAL tree ?
>> >> > >> >> >> Integrating
>> >> > >> >> >> them into
>> >> > >> >> >> mainline GDAL would probably make life of Japanese users
>> >> > >> >> >> easier.
>> >> > >> >> >> GDAL
>> >> > >> >> >> has already support for a lof of national specific formats,
>> >> > >> >> >> mainly
>> >> > >> >> >> in
>> >> > >> >> >> Europe and
>> >> > >> >> >> North America. Would be cool for Asia to join in ;-)
>> >> > >> >> >> In a recent discussion thread, the following link is
>> >> > >> >> >> mentionned:
>> >> > >> >> >> https://www.dropbox.com/s/4oyhncknavdk2if/gdal110_test.zip
>> >> > >> >> >> I can see that it contains 2 new GDAL drivers ( FGD: Japanese
>> >> > >> >> >> Fundamental Geographic Data (.xml) & FG-GML : Japanese
>> >> > >> >> >> Fundamental
>> >> > >> >> >> Geographic Data GML(.xml) ) and one OGR driver (FGD).
>> >> > >> >> >> Unfortunatelly there's no author or copyright information in
>> >> > >> >> >> the
>> >> > >> >> >> header of the
>> >> > >> >> >> corresponding source files. Would their author(s) be willing
>> >> > >> >> >> to release them
>> >> > >> >> >> under the X/MIT license and contribute them to the mainline
>> >> > >> >> >> GDAL
>> >> > >> >> >> project ? Perhaps some test files to write minimalistic
>> >> > >> >> >> regressions
>> >> > >> >> >> tests would be useful.
>> >> > >> >> >> Let me know if I can be useful for anything. I can also help
>> >> > >> >> >> for
>> >> > >> >> >> writing new
>> >> > >> >> >> drivers if needed.
>> >> > >> >> >> Best regards,
>> >> > >> >> >> Even
>> >> > >> >> >> Spatialys - Geospatial professional services
>> >> > >> >> >> http://www.spatialys.com
>> >> > >> >> >> _______________________________________________
>> >> > >> >> >> OSGeoJapan-discuss mailing list
>> >> > >> >> >> OSGeoJapan-discuss @ lists.osgeo.org
>> >> > >> >> >> http://lists.osgeo.org/mailman/listinfo/osgeojapan-discuss
>> >> > >> >> > Hiroo Imaki
>> >> > >> >> > Pacific Spatial Solutions, LLC
>> >> > >> >> > 1523 Chatham Colony Ct.
>> >> > >> >> > Reston, VA 20190
>> >> > >> >> > hiroo.imaki @ pacificspatial.com
>> >> > >> >> > http://www.pacificspatial.com
>> >> > >> >> > http://www.geopacific.org (GIS info site)
>> >> > >> >> > hiroo @ angeli.org (private)
>> > Hiroo Imaki
>> > Reston, VA 20190
Ko Nagase (長瀬 興)
Georepublic Japan
mail: nagase @ georepublic.co.jp
web: http://georepublic.co.jp
OSGeoJapan-discuss メーリングリストの案内
