[Oskari-user] Installing Oskari Map Application using EPSG:3067 as a default coordinate system
Keijo Kangas
keijo.kangas at kuntotekniikka.fi
Mon Aug 6 01:13:03 PDT 2018
Hello,
I removed the contents of the geoserver_data folder and set the coordinate
system to EPSG:3067 using http://localhost:8080/setup. After that
Geoservers native SRS is set to EPSG:3067. Thank you.
Keijo Kangas
+358 40 480 9035
Sovelluskehittäjä
<http://www.kuntotekniikka.fi/> www.kuntotekniikka.fi
<http://www.facebook.com/kuntotekniikka> www.facebook.com/kuntotekniikka
Lähettäjä: Mäkinen Sami (MML) <sami.makinen at maanmittauslaitos.fi>
Lähetetty: 6. elokuuta 2018 10:54
Vastaanottaja: Sanna Jokela <sanna at gispo.fi>; Keijo Kangas
<keijo.kangas at kuntotekniikka.fi>
Kopio: Oskari-user at lists.osgeo.org
Aihe: VS: [Oskari-user] Installing Oskari Map Application using EPSG:3067 as
If you have the GeoServer address and credentials setup in
oskari-ext.properties you can delete the contents of the geoserver_data
folder under Jetty to get rid of the pre-populated configuration. Then after
starting Jetty go to http://localhost:8080/setup. You will see one text
field and a button. Type in EPSG:3067 and click the button. This will
configure GeoServer with everything Oskari needs and set the native
projection. It will also advice you if you need to change something in
oskari-ext.properties regarding myplaces, analysis or userlayers.
Note that after you have done this you will want to move the setup.war from
under Jetty webapps so users won't be able to access it. The setup webapp is
a bit experimental and not very pretty but it's the simplest way to
configure GeoServer for Oskari and it's included in the download from
oskari.org. Also note that it uses the GeoServer REST API for configuration
and probably won't work with other GeoServer versions than the bundled one
as the GS API has changed since.
Would be nice if someone developed the setup further for other aspects of
Oskari as well :)
BR,
Sami
_____
Lähettäjä: Sanna Jokela <sanna at gispo.fi <mailto:sanna at gispo.fi> >
Lähetetty: 6. elokuuta 2018 7:55
Vastaanottaja: Keijo Kangas; Mäkinen Sami (MML)
Kopio: Oskari-user at lists.osgeo.org <mailto:Oskari-user at lists.osgeo.org>
Aihe: Re: [Oskari-user] Installing Oskari Map Application using EPSG:3067 as
Good morning!
Has Sami some ideas on this? I have been on on vacation, so sorry for the
delay in answering. I have also heard some similar problems with projections
in another case, so it would be great to document this better.
Br,
Sanna
On 2 August 2018 at 11:23, Keijo Kangas <keijo.kangas at kuntotekniikka.fi
<mailto:keijo.kangas at kuntotekniikka.fi> > wrote:
Hello,
I am installing Oskari Map Application using pre-installed environment with
these instructions: http://oskari.org/documentation/backend/setup-jetty
However, I want to set default coordinate system to EPSG:3067 and set it to
oskari-ext.properties before starting the start.jar (java -jar start.jar)
but when I log in to pre-installed Geoserver I can see that the Native SRS
is EPSG:4326. How can I set the default coordinate system to EPSG:3067 so
that Oskari Map installation process creates oskaridb database tables and
geoserver Layers compatible to EPSG:3067 coordinate system? Thank you for
your help!
Keijo Kangas
+358 40 480 9035
Software developer
Oskari-user mailing list
https://lists.osgeo.org/mailman/listinfo/oskari-user
Sanna Jokela
paikkatietoasiantuntija
Gispo Oy
0407664607
www.gispo.fi <http://www.gispo.fi>
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20180806/27ca9157/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20180806/27ca9157/attachment-0001.png>
More information about the Oskari-user
