[Oskari-user] [Incubator] Oskari Incubation status
Cameron Shorter
cameron.shorter at gmail.com
Thu Jul 5 10:02:21 PDT 2018
Arnulf, to answer your question at the bottom, yes I read to the bottom,
and really appreciate your detailed assessment.
Based on Arnulf's assessment, it sounds like Sskari probably has a good
codebase, with good work from within one organisation, but is yet to
attract engaged external developers. This is a great milestone, and
worth acknowledging. But the "unicorn" projects that we look for in
OSGeo incubation are those with a healthy community from multiple
organisations.
The "extent of collaboration" criteria provides validation of the
quality of the project, and is a very good indicator of long term
sustainability.
To the Oskari folks, you might want to read this presentation I gave a
while back on business justifications for backing collaboration:
http://cameronshorter.blogspot.com/2017/11/open-source-pitch-for-your-boss.html
Without digging into the details any further, I suspect Oskari would
need to work on attracting co-contributors, from multiple organisations,
and we would likely see evidence of this happening by seeing archive
logs of collaborative email lists, or slack or IRC or similar.
Warm regards, Cameron
On 6/7/18 2:11 am, Arnulf Christl (Metaspatial) wrote:
> Hi Folks,
> this is an update on the Incubation process of Oskari.
> https://wiki.osgeo.org/wiki/Oskari_Incubation_Status
> As mentor I am still somewhat hesitant to recommend Oskari for OSGeo
> Incubation because I cannot find a good indicator supporting that
> there is an open community and communication. Personally I know some
> of the current core team and totally trust them to work in the Open
> Source way of doing things. But this may not be quite apparent to
> anybody not into the project.
> Oskari is doing a good job posting news and updates to the OSGeo user
> list (https://lists.osgeo.org/pipermail/oskari-user/) but the list is
> not really used by users for any kind of discussion, help or future
> development. It feels more like a low volume announce list (which is
> totally OK, so please keep it up).
> How and where is the development being discussed? Who can join the
> Oskari Slack channel - or whatever else is used to have technical and
> strategic discussions? Are there archives of discussions and
> decisions? Do you manage to do this in English or is it still
> everything communicated in Finnish?
> In a PSC presentation from December 2016 one bullet-point says that
> Oskari may become a project on OSGeo live:
> https://oskariorg.github.io/files/20161220-Oskari_OSGEO_PSC.pdf.
> <https://oskariorg.github.io/files/20161220-Oskari_OSGEO_PSC.pdf>
> Actually, Incubation is not a requirement, so please feel free to
> approach the OSGeo Live team to find out more.
> In the Roadmap document (which in my opinion is actually ery good) at:
> https://github.com/oskariorg/oskari-docs/wiki/Roadmap-process you say
> that:
> /"After communicating with Oskari community the roadmap items enter
> Active stage [...]". /
> Can you give us an example of where and how this has happened?
> There are some updates on GitHub issues but it appears to be mostly
> internal team members (which is totally OK, is this where the
> collaborative aspect of the future development takes place?
> https://github.com/oskariorg/oskari-docs/labels/roadmap
> Regarding Code Copyright Review you state that:
> /All code has been developed by the registered developers listed on
> github who have signed the CLA. All external libraries have project
> compatible licenses. The project has been started as a regular Open
> Source project following the guidelines as set out by OSGeo. A
> file-per-file code review was therefore deemed superfluous. /
> As mentor I can confirm that this is correct and satisfies OSGeo's
> requirements (and yes, I did some quick checks on random code files
> but due to the well organized origin of the project did not go through
> all code like we had to in the GRASS project... :-).
> In the last PSC meeting in December 2017 a decision was taken to
> schedule the next meeting "as needed".
> /Meetings/activity/
> * /future meetings schedule: continue with “as needed” (no need for
> a fixed schedule)/
> Summarizing the current status: We discussed some of the above topics
> before and it is not a requirement for OSGeo Incubation to have active
> mailing lists and so on. But it is a requirement to have an open
> process and ideally also a somewhat growing user community. Obviously
> due its character as a complex portal platform Oskari is not a
> software that will have millions of downloads but a little broader
> adoption would be nice to see.
> You also say:
> * /Slack/Mailinglist can be used more actively to discuss any
> issues/voting/
> If you are not using the Slack channel (which unfortunately is not
> open), where is the communication taking place?
> The PSC meeting notes from December 2017 has a list of current
> installations / users / contributions. This is good to see. Has there
> been any additions, changes over the past half year?
> Even if you can not produce evidence for any or all of the above
> issues I will be happy to recommend Oskari for Incubation if you
> believe that this will help the project. Then it will be up to the
> Incubation committee to decide whether we can recommend graduation to
> the OSGeo Board of Directors.
> We will have to expect some discussion on the Incubation list on the
> above topics and this is not bad but a sign of a healthy process.
> Internal note to the Incubation committee
> IF you ever made it down to this line and maybe even checked some of
> the referenced documents, please be so kind as to acknowledge this on
> the mailing list so that we can help Oskari move on.
> It may also be a good idea to go back to the Incubation process and
> check whether it should be revised for certain aspects (especially
> requirement on mailing lists / alternatives like Slack).
> Anything else you need, let me know.
> Thank you,
> Arnulf
> Am 2018-06-25 um 17:05 schrieb Aarnio Timo (MML):
>> Hi Incubator-list!
>> We’d like to inquire about the incubation status of Oskari. What are
>> the next steps should be in the incubation process? In our end we’ve
>> done everything we’ve realized that we have to do. But is there
>> something still wanted from us? Or is the process in the OSGeo end
>> now? If so, what are the steps there and is there possibly any
>> estimate when we can think about graduating?
>> Kind regards,
>> Timo Aarnio
>> Incubator mailing list
>> Incubator at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/incubator
> Spatially enabling your business
> http://metaspatial.net
Cameron Shorter
Technology Demystifier
Open Technologies and Geospatial Consultant
M +61 (0) 419 142 254
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20180706/ebc55c04/attachment-0001.html>
More information about the Oskari-user
