[Oskari-user] Hotfix 2.14.2 released and upcoming 3.0
Mäkinen Sami sami.makinen at maanmittauslaitos.fi
Tue Jan 28 07:13:11 PST 2025
Good news everyone,
a hotfix (2.14.2) for the latest version was released yesterday for Oskari-frontend. This fixes issues for admins regarding organizing map layers in subgroups and a fix for visual presentation of the zoombar when 3d effect is used on theming.
We are currently working with the upcoming 3.0 release and currently estimating March as the release window. We are making good progress on it with tons of library updates and the migration from Java 8 to Java 17 as the compile target. Notice that due to the library updates we will need to update the server software we package the sample application with and this is also a required update when updating to 3.0. We are likely to change from Jetty 9 to Tomcat 10 on the download package. You can still use Jetty, but will need to update to a version that supports the Jakarta namespace for servlets.
If you want to follow the progress and possibly even test out the changes before the release, here are some links to check through for tracking the upcoming changes:
  *   Server milestone: https://github.com/oskariorg/oskari-server/milestone/52?closed=1
  *   Frontend milestone: https://github.com/oskariorg/oskari-frontend/milestone/53?closed=1
  *   Currently identified issues that we are working on: https://github.com/oskariorg/oskari-documentation/milestone/1
On the frontend side everything has been merged to develop and on the server side we are currently working on the java17 branch: https://github.com/oskariorg/oskari-server/tree/java17 with the Jakarta namespace change being merged in the upcoming days. You can already find the compiled  3.0.0-SNAPSHOT versions on the Oskari.org maven repository.
Cheers,
Sami
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20250128/40b894a3/attachment.htm>
More information about the Oskari-user mailing list
