[Ottawa_users] Lat Long Calculations
Adair, Mike
adair at NRCan.gc.ca
Thu Jun 28 15:46:28 EDT 2007
Dave,
I have some Great Circle calculation code in Perl that you could have,
just don't ask me to explain it ;-)
Mike
> -----Original Message-----
> From: ottawa_users-bounces at lists.osgeo.org
> [mailto:ottawa_users-bounces at lists.osgeo.org] On Behalf Of
> Frank Warmerdam
> Sent: Wednesday, June 27, 2007 14:30
> To: Ottawa (Canada) Local Chapter List
> Subject: Re: [Ottawa_users] Lat Long Calculations
> Sampson, David wrote:
> > Thanks Frank,
> > I was looking into maybe doing a projection to UTM, but I fear
> > problems when a distance is calculated across two different UTM
> > zones... Does this matter?
> Dave,
> It is important that both points can be converted to a
> projection that is well behaved (low error) in the area
> containing the points.
> Cross UTM zone edges isn't a problem, but the further you go
> "out of the zone" the greater the distortion. It would
> likely be better to use a custom projection centered between
> your two points. I'm not exactly sure what projection would
> be best though since my projection "theory" is pretty weak.
> > I looked at GEOS and found that there are measurements between
> > geometry objects.
> http://geos.refractions.net/ro/doxygen_docs/html/namespacegeos_1_1oper
> > at
> > ion_1_1distance.html
> > But getting into the GEOS library from python is proving a
> challenge.
> > Some posts even note that the measure function is not
> exposed to the C
> > API of Geos (FRANK?)
> > http://lists.maptools.org/pipermail/fwtools/2006-March/000318.html.
> GEOS is just doing a cartesian, not great circle,
> calculation. So you might as well do it yourself in python.
> > So what about the measuremnt function from PCL? Well I am
> having to
> > battle PCL install on windows using FWTools. If this works
> I hope this
> > is even what I want. Furthermore I hope I can compile and
> package up
> > an application without an FWTOOLS dependency.
> I can't speak for what PCL has built in. I think mixing PCL
> binaries and FWTools is likely to be a nightmare though it
> might be possible to graft pure python parts of PCL into
> FWTools. Generally though if PCL isn't doing anything
> special for you, then it likely isn't worth while.
> > I would have thought someone would have a compas.py program
> that would
> > do all this, but I guess it's so simple that everyone
> reinvents their
> > own wheel when they need it. My chissel is not that precise
> to carve a
> > new wheel. (SMILE)
> I imagine such a thing exists somewhere. Finding and
> integrating may prove a challenge. If you are willing to use
> cartesian distances in a projection between points then there
> is really no reason not to do the distance yourself, using
> osr.py to reproject things.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo,
> http://osgeo.org
> Ottawa_users mailing list
> Ottawa_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/ottawa_users
More information about the Ottawa_users
