[Ottawa_users] Clipping shapefiles with ogr2ogr
Christy Nieman
cnieman at connect.carleton.ca
Thu Feb 21 13:54:50 EST 2008
I have no idea. My only suggestion would be to try loading the
shapefile into the GRASS mapset again.
Christy
Alyre Chiasson wrote:
> Hi Christy,
> Thanks for the offer of help. I believe I understand your
> instructions. I have gotten as far as having the GRASS clip mask and
> the underlying GRASS layer from which I want to retain the underlying
> feature. So if I could cut out what is under the mask, I would have my
> desired result. Look good at this stage on the screen. However, when I
> execute the v.overlay I get the following error, "Database connection
> not defined for layer 1" No layer is created and QGIS freezes then
> crashes when I try to exit. Any idea what this message means. Seems
> like some related to the database pathway? Did something not get
> properly imported from the shapefiles? How do I correct it?
> Thanks
> Alyre
> Loader
> Christy Nieman wrote:
>> Hi,
>> I just spent a while working on clipping in QGIS/GRASS, and it is
>> quite simple. I used the GRASS Tools plugin for QGIS to load my
>> shapefiles into a GRASS mapset. I then converted my mapset's region
>> to a GRASS vector layer to use as the overlay layer in the clip
>> (v.in.region - under Vector/Create standard vectors in the QGIS GRASS
>> tools dialog). Then I used the v.overlay intersection tool to do the
>> clip. This has to be done one layer at a time.
>> If you need more details I can provide a specific example.
>> Christy
>>> Hello,
>>> I suspected that something like below was happening, although the
>>> documentation I read regarding the -spat option presents it as a
>>> clipping function. I was surprised by the result. I am new to all of
>>> this and have no computer science background so I am not familar
>>> with a "bbox" . Although I know Python is a flexible multi platform
>>> language (I see a lot of references in the Linux world), attempting
>>> to learn the language to write a script to do this job or to
>>> understand someone else's script I believe would be beyond my time
>>> constraints for the current project. I did try to import both shape
>>> files into GRASS as layers and then tried to overlay (v.overlay)
>>> them but got error messages which I couldn't understand but were
>>> basically complaining about missing attributes. Not sure what
>>> attributes it was referring to. Is there actually no way to do this
>>> within GRASS or QGIS that retains the feature of the shapefile
>>> (everthing within the clipping region) without having to learn a
>>> programming language? Would seem to be a desirable function. Not
>>> adverse to learning a program language but it would be a much longer
>>> term goal.
>>> Thanks
>>> Alyre
>>> ----- Original Message ----
>>> From: Tyler Mitchell (OSGeo) <tmitchell at osgeo.org>
>>> To: Ottawa (Canada) Local Chapter List <ottawa_users at lists.osgeo.org>
>>> Sent: Monday, February 18, 2008 12:26:36 PM
>>> Subject: Re: [Ottawa_users] Clipping shapefiles with ogr2ogr
>>> On 18-Feb-08, at 6:22 AM, Paul Spencer wrote:
>>> > My first guess is that ogr2ogr doesn't clip, it uses the bbox as a
>>> > spatial selection and keeps anything that intersects with the >
>>> bbox. Would this account for your results?
>>> That's right, it cannot clip, but will select/return all features
>>> that fit in the area. You can't use ogr2ogr for clipping but I
>>> believe you could write a Python script that calls the OGR and GEOS
>>> functions to do this job.
>>> Tyler
>>> Ottawa_users mailing list
>>> Ottawa_users at lists.osgeo.org <mailto:Ottawa_users at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/ottawa_users
>>> Ask a question on any topic and get answers from real people. *Go to
>>> Yahoo! Answers.* <http://ca.answers.yahoo.com>
More information about the Ottawa_users
