[Ottawa_users] New Brunswick User looking for help with GRASS
and Quantum GIS - may be of interest to new users
Alyre Chiasson
alyrechiasson at yahoo.ca
Tue Jan 22 16:48:16 EST 2008
Hello all,
Thanks for all the offers of help and the suggestion to do an initial
post. Perhaps a quick explanation of what I am attempting to do would be
in order as well as what resources I have on hand. I have the book,
“Open Source GIS: A GRASS GIS Approach” by Netler and Mitasova (second
edition, and I just got the third yesterday) and have printed out an
“Introduction to the practical use of the Free Geographical Information
System GRASS 6.0,” so you can point me to specific pages that might be
of help that I may have overlooked.
I have a bunch of shape files from Environment Canada with predicted
maximum air temperature increases for New Brunswick (they are actually
of the whole Atlantic Region from what I can see) in 30 year blocks to
2100 (Dataset A). They do have “prj” files. Example:
GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]
They come up as isotherms (contour lines) and are labeled; the labels
are in a dbf file.
I also have shapefiles for the rivers and streams in New Brunswick,
including (site/point) data with watercourse names (Dataset B). They
also have “prj” files. They also include basic boundaries to the
province. Again, here is the prj file.
I also have data on mean maximum water temperatures for various rivers
across New Brunswick (Dataset C). They are current in an Excel
spreadsheet and have the following format:
CoordinateSystem XCoordinate YCoordinate CoordinateUnits
NAD83 (CSRS) NB Stereographic 2394846.697 7657396.666 Meters
I also have upper lethal temperature data for most of the freshwater
fish of New Brunswick. You can get predicted water temperatures by
multiplying air temperature by 0.9 and adding it to the base water
temperature. The idea would be for each site where baseline water
temperatures are known, the nearest isotherm would be chosen and the
predicted increase for that site calculated and labeled. I was also
hoping to be able to superimpose on this a layer that would flag
temperatures above a certain value. For example, if it happened to be
Atlantic salmon, there would be a red dot above 24 C. Increasing red
dots over time would means progressive loss of the species (main point
of the exercise).
I also bought a copy of NBGEOCALC from Services New Brunswick, which
they describe as:
NBGeocalc is a piece of software designed by SNB to help with coordinate
conversions and transformations in New Brunswick. It is the accepted
standard for transforming coordinates from/to ATS77 and NAD83 (CSRS). It
is also a very useful tool to convert in all directions, latitudes /
longitudes and UTM coordinates
I figure I might get some water temperature data from sports clubs but
in lat and long.
From the provincial web site I found that the province uses something
called NAD83 (CSRS) Double Sterographic, a screen capture of parameters
is attached (image2). I have also found that this corresponds to EPSG
code 2953. Out of this I see two options:
1) Stick with NAD83 of datasets A and B and use GEOCALC to translate the
coordinates of dataset 3. Other than being compatible with the province
and I don’t know what the advantage of Double Stereographic is and maybe
it does not make a difference for what I want to do.
2) The other option is to covert dataset A and B (shapefiles) and
creates a LOCATION and mapset based on a Double Stereographic
Projection. I have created a LOCATION using EPSG code 2953 and get the
following output from g.proj.
PROJCS["Stereographic",
GEOGCS["unnamed",
DATUM["unknown",
SPHEROID["unnamed",6378137,298.257222101]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Oblique_Stereographic"],
PARAMETER["latitude_of_origin",46.5],
PARAMETER["central_meridian",-66.5],
PARAMETER["scale_factor",0.999912],
PARAMETER["false_easting",2500000],
PARAMETER["false_northing",7500000],
UNIT["metre",1]]
My first concerns are the “unkown”s and the second is that the
projection is listed as “Oblique Sterographic” and not “Double”. Maybe
“Oblique” is actually a “Stero” projection? Somewhat disconcerting for
someone starting out. I confirmed the EPSG code from:
http://spatialreference.org/ref/epsg/2953/
I am also confused as to what kind of coordinate system is being used
above (Double Sterographic). Seems like a form of UTM? As a question, if
I was to create the LOCATION from scratch based on UTM, how would I go
about representing New Bruswick as a LOCATION that actually physically
lies within 2 UTM zones? All of the examples that create LOCATIONs based
on UTM that I have seen so far are silent on what you do if your
LOCATION covers more than one zone. Can you actually query across two
LOCATIONs, is that the solution? So what are “Sterographic” coordinates,
does everything become the equivalent of a single zone and the
projection corrects for errors involved in extrapolating for what would
be otherwise traversing from one zone to another?
Assuming that everything above is okay I grasp that I need to reproject
the shape files and convert the coordinate system. By example, I have a
shape file called nbmjwatr.shp and its associated prj file (first
example above). From what I have read so far the conversion can be done
with org2org. I am not sure what the command would be, I can’t find an
example where the particular prj files is specified or is it
automatically read if it is in the same directory? So would the command be
org2org nbmjwatr.shp \ -spat -60.05 35.00 -63.78 48.07 \ my_nbmjwatr.shp
The –spat is to cut out the boundaries to fit my the EPSG 2953 specified
boundaries.
I have tried something similar and got a string of errors saying I
needed to provide the transformation information. I may just have the
wrong command. If I extract this from the top prj file above, would the
following do the job
org2org -a_srs ‘+proj=latlong +ellps= GRS80 +datumn=NAD83’ \ -spat
-60.05 35.00 -63.78 48.07 \ my_nbmjwatr.shp nbmjwatr.shp
I assume the dbf file gets imported as well. What happens to the labels
which are in the dbf file? In the original shapefiles from Environment
Canada the labels are missing from the upper part of New Brunswick
because in the original they are over Nova Scotia (image1). Will the
labels be readjusted when the original file gets clipped? I can’t fine
anything on how label placement is determined. However, the first hurdle
is getting the basic maps into GRASS because I don’t think Quantum can
do the above.
I don’t know if GRASS can do the nearest neighbour isotherm type of
calculation I have proposed above with some king of script but I will be
doing more reading or you can suggest where I might look. Unless Quantum
would be an easier tool to do the above, I wanted to use it mainly as a
viewer for the resulting product.
I may be well over my head here but part of this was to see how
difficult the whole business would be. The Open Source approach was in
part because of my involvement with watershed groups that can’t afford
commercial GIS software but could profit from using GIS to look at their
data. My best course of action may be to hire someone to actually get
the work done first (priority) and I try to duplicate it with GRASS or
Quantum on my part. I get blank stares here when I mention either GRASS
or Quantum or anything Linux so it would be alternative GIS software if
I was to hire someone.
Just as background I am a biology professor of 20 years in a relatively
small university (Université de Moncton), in New Brunswick. So I guess I
am somewhat of an old dog trying to learn new things. The Apple IIe came
out when I was doing my doctorate :) and I actually cut my first teeth
on a Unix system so command lines don't bother me.
Thanks in advance for any suggestions/advice or help you care to offer.
If this is not of general interest I can carry on by email with anyone
that might want to help a somewhat lost soul. I guess, I am a good
example of someone coming from outside of the specific field of GIS.
Thanks
Alyre
Type: image/bmp
Desc: not available
Url : http://lists.osgeo.org/pipermail/ottawa_users/attachments/20080122/5a276d3e/Image1-0001.bmp
Type: image/bmp
Desc: not available
Url : http://lists.osgeo.org/pipermail/ottawa_users/attachments/20080122/5a276d3e/Image2-0001.bmp
More information about the Ottawa_users
