[owslib-devel] wps branch available
Cinquini, Luca (3880) Luca.Cinquini at jpl.nasa.gov
Wed Nov 9 12:56:07 PST 2011
Hi Dom,
	thanks for the additional example... I noticed that your service uses the namespace "http://www.opengeospatial.net/wps", while the other two WPS services I have tested against use "http://www.opengis.net/wps/1.0.0".
>From the OGC web site it looks like the second namespace should be the correct one (see for example: http://schemas.opengis.net/wps/1.0.0/wpsGetCapabilities_request.xsd),
but maybe I am wrong and we need to support both ? Would you know what is the correct way to go ?
thanks, Luca
On Nov 9, 2011, at 6:56 AM, Dominic Lowe wrote:
> Luca,
> Many thanks for your contributions.
> We also have a WPS server (implemented in Python) that you could test
> against:
> http://ceda-wps2.badc.rl.ac.uk/wps?Service=WPS&Request=GetCapabilities&Format=text/xml
> The following "DoubleIt" process can be called without security
> (DescribeProcess):
> http://ceda-wps2.badc.rl.ac.uk/wps?Service=WPS&Request=DescribeProcess&Version=1.0.0&Identifier=DoubleIt
> Regards,
> Dom
> On 08/11/11 23:10, Luca.Cinquini at jpl.nasa.gov wrote:
>> Hi Jorge,
>> 	these are great examples... if you give me one day (at most two) I will expand the code to support them, and provide some tests and examples... I'll let you know when you can start giving it a try...
>> thanks, Luca
>> On Nov 8, 2011, at 3:18 AM, Jorge de Jesus wrote:
>>> Ciao Luca
>>> Excellent job, we should all buy you some beer :)
>>> It's really nice that you are using the USGS WPS since it is  a 52North
>>> WPS instance, the owslib should be tested against the major WPS
>>> implementations (Zoo, degree etc), maybe you could make an introduction
>>> of owslib in other mailing list and get their support.
>>> Anyway if you need you can use the PML WPS instances (vector and raster
>>> instances are mainly WPS-Grass-Bridge processes)
>>> Support page:
>>> http://rsg.pml.ac.uk/wps/index.html
>>> Test data page:
>>> http://rsg.pml.ac.uk/wps/testdata/index.html
>>> Examples:
>>> http://rsg.pml.ac.uk/wps/generic.cgi?request=Execute&service=wps&version=1.0.0&identifier=reprojectImage&datainputs=[inputImage=http://rsg.pml.ac.uk/wps/testdata/elev_srtm_30m.img;outputSRS=EPSG:4326]&responsedocument=outputImage=@asreference=true
>>> http://rsg.pml.ac.uk/wps/generic.cgi?request=Execute&service=WPS&version=1.0.0&identifier=reprojectCoords&datainputs=[coords=http://rsg.pml.ac.uk/wps/testdata/coords.txt;outputSRS=EPSG:32630;inputSRS=EPSG:4326]
>>> http://rsg.pml.ac.uk/wps/vector.cgi?request=execute&service=WPS&version=1.0.0&identifier=v.net.path&datainputs=[input=http://rsg.pml.ac.uk/wps/example/graph.gml;file=1%20-960123.1421801624%204665723.56559387%20-101288.65106088226%205108200.011823481]
>>> I'll give a look at the code and test it
>>> Jorge
>>> On 07/11/11 14:42, Cinquini, Luca (3880) wrote:
>>>> Hi all,
>>>> 	I have created a wps branch of owslib that contains a first draft support for WPS.
>>>> The branch is available here: https://owslib.svn.sourceforge.net/svnroot/owslib/branches/wps
>>>> The module has been tested against the USGS WPS service - does anybody know of another service to test against ?
>>>> A good starting point to test functionality is the file README_WPS.txt
>>>> All WPS functionality is included in separate files, except for a small addition to util.py to set the 'text/xml' header for a POST request.
>>>> All feedback appreciated,
>>>> thanks, Luca
>>>> RSA(R) Conference 2012
>>>> Save $700 by Nov 18
>>>> Register now
>>>> http://p.sf.net/sfu/rsa-sfdev2dev1
>>>> _______________________________________________
>>>> owslib-devel mailing list
>>>> owslib-devel at lists.sourceforge.net
>>>> https://lists.sourceforge.net/lists/listinfo/owslib-devel
>>> Plymouth Marine Laboratory
>>> Registered Office:
>>> Prospect Place
>>> The Hoe
>>> Plymouth  PL1 3DH
>>> Website: www.pml.ac.uk
>>> Click here for PML Annual Review
>>> Registered Charity No. 1091222
>>> PML is a company limited by guarantee
>>> registered in England&  Wales
>>> company number 4178503
>>> Please think before you print
>>> This e-mail, its content and any file attachments are confidential.
>>> If you have received this e-mail in error please do not copy, disclose it to any third party or use the contents or attachments in any way. Please notify the sender by replying to this e-mail or e-mail forinfo at pml.ac.uk and then delete the email without making any copies or using it in any other way.
>>> The content of this message may contain personal views which are not the views of Plymouth Marine Laboratory unless specifically stated.
>>> You are reminded that e-mail communications are not secure and may contain viruses. Plymouth Marine Laboratory accepts no liability for any loss or damage which may be caused by viruses.
>>> <0x595FF9D3.asc>
>> Save $700 by Nov 18
>> Register now
> Scanned by iCritical.
> Save $700 by Nov 18
> Register now
More information about the OWSLib-devel mailing list
