[OWSLib-devel] TMS Implementation
Jachym Cepicky
jachym.cepicky at gmail.com
Tue Jan 29 13:09:18 PST 2013
cool stuff, thanks
Jachym
Dne 29.1.2013 07:05, Christian Ledermann napsal(a):
> On Tue, Jan 29, 2013 at 3:53 AM, Tom Kralidis <tomkralidis at hotmail.com> wrote:
>> Merged -- thanks very much Christian!
>> I notice some additions to setup.py for tests.
> I used his setup for fastkml and pygeoif. I think this is the
> easiest way from an end users point of view. Just run
> # python setup.py test
>> The codebase is in desperate
>> need of some testing setup, like getting this hooked up to travis-ci, etc.
> with the setup.py test approach most test fail currently (tms.txt passes :p ):
> Ran 35 tests in 97.818s
> FAILED (failures=31)
> some of the failures are because the url changed or the service
> is not available, others because the file could not be found.
>> On the todo list, contributions welcome.
>>> Date: Mon, 28 Jan 2013 13:40:45 +0300
>>> Subject: Re: [OWSLib-devel] TMS Implementation
>>> From: christian.ledermann at gmail.com
>>> To: tomkralidis at hotmail.com
>>> CC: owslib-devel at lists.osgeo.org
>>> https://github.com/geopython/OWSLib/pull/50
>>> On Fri, Jan 11, 2013 at 4:56 PM, Christian Ledermann
>>> <christian.ledermann at gmail.com> wrote:
>>>> I want to do some more testing and add some features first
>>>> @list: if you have some wishes what features should
>>>> be implemented (and how) please add at
>>>> https://github.com/geopython/OWSLib/issues/48
>>>> On Fri, Jan 11, 2013 at 4:47 PM, Tom Kralidis <tomkralidis at hotmail.com>
>>>> wrote:
>>>>>> Date: Fri, 11 Jan 2013 08:55:13 +0300
>>>>>> On Thu, Jan 10, 2013 at 8:31 PM, Tom Kralidis
>>>>>> wrote:
>>>>>>> Christian: thanks for the info. Yes indeed please issue a PR I think
>>>>>>> this is
>>>>>>> a valuable addition!
>>>>> Thanks -- I can't see the PR on GitHub, can you send a pull request?
>>>> Best Regards,
>>>> Christian Ledermann
>>>> Nairobi - Kenya
>>>> Mobile : +254 702978914
>>>> If you save the living environment, the biodiversity that we have left,
>>>> you will also automatically save the physical environment, too. But If
>>>> you only save the physical environment, you will ultimately lose both.
>>>> 1) Don’t drive species to extinction
>>>> 2) Don’t destroy a habitat that species rely on.
>>>> 3) Don’t change the climate in ways that will result in the above.
>>> Best Regards,
>>> Christian Ledermann
>>> Nairobi - Kenya
> Best Regards,
> Christian Ledermann
> Nairobi - Kenya
> OWSLib-devel mailing list
> OWSLib-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/owslib-devel
Jachym Cepicky
Help Service - Remote Sensing s.r.o.
HS-RS: jachym at hsrs.cz http://bnhelp.cz
http://les-ejk.cz
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/owslib-devel/attachments/20130129/d76be96e/attachment.pgp>
More information about the OWSLib-devel
