[OWSLib-devel] bug in SOS 1.0.0 get_observation?
Joe Futrelle
jfutrelle at whoi.edu
Fri Nov 1 12:00:35 PDT 2013
Thanks Kyle! I'm new enough to pip and git that I didn't know pip could
do that trick! Perfect.
On 11/01/2013 03:02 PM, Kyle Wilcox wrote:
> Hi Joe -
> Thanks for the report! This was fixed a few weeks ago but there has not been an OWSLib release yet:
> https://github.com/geopython/OWSLib/commit/5a79acccebbfe310c8ceb9f5532e32991510d8d1
> If you install OWSLib using this command it should work as expected: `pip install git+https://github.com/geopython/OWSLib.git`
>> -----Original Message-----
>> From: owslib-devel-bounces at lists.osgeo.org [mailto:owslib-devel-
>> bounces at lists.osgeo.org] On Behalf Of Joe Futrelle
>> Sent: Friday, November 01, 2013 2:41 PM
>> To: owslib-devel at lists.osgeo.org
>> Subject: [OWSLib-devel] bug in SOS 1.0.0 get_observation?
>> I hope I'm posting this to the right list.
>> Reading the owslib/swe/observation/sos100.py it appears that
>> get_observation only returns a response in exception handlers. When all
>> those fall through it returns None, which I don't think is correct.
>> This is in release version 0.8.2, here's the offending section of the code:
>> response = openURL(base_url, data, method,
>> username=self.username, password=self.password).read()
>> try:
>> tr = etree.fromstring(response)
>> if tr.tag == nspath_eval("ows:ExceptionReport", namespaces):
>> raise ows.ExceptionReport(tr)
>> except ows.ExceptionReport:
>> raise
>> except BaseException:
>> return response
>> I think the fix is just to add a return clause immediately after the except
>> clauses?
>> Apologies if this is me not understanding the API.
>> Or if this has already been patched.
>> And the other usual disclaimers.
>> Joe Futrelle
>> Woods Hole Oceanographic Institution
>> OWSLib-devel mailing list
>> OWSLib-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/owslib-devel
Joe Futrelle
More information about the OWSLib-devel
